Author Topic: my themo pex install ...so far  (Read 8686 times)
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« on: July 02, 2014, 02:59:49 PM »
I off and running!!   install in progress!  1st pic is of 5' of peeled pipe ...so I can insert it into my 6" abs pipe that I have under the slab and stubbed up into the inside slab> I also placed a hard plastic line in between them so once i'm done I can "add spray foam and seal the line from the inside to the out side !  ;)       2nd pic is oF the black mean snake laying in the yard :-X ..waiting to fight with me !    3rd pic ..Is just a shot  looking  down> "the white foam surrounding my shop" pipe to enter under footing is under it ....(slab on grade)   4thpic>   it my thermo pex INSIDE a 6" pipe ..the flex stuff u buy in a coil  at the big orange " home death spot" (THD)...I ran some 10/3 wire along with it ...more to come as I plan to box in the pipe ...like a T with two  legs   insulation on both side and a board of it across the top
« Last Edit: July 02, 2014, 03:15:48 PM by atvalaska »
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: my themo pex install ...so far
« Reply #1 on: July 25, 2014, 08:17:55 PM »
Does that stuff bend easier than the stuff with the smooth outer shell?
« Reply #2 on: July 26, 2014, 03:40:17 AM »
Yes Thermo Pex does bend easier, the corrugated outer layer is also thinner and the water lines are nominally sized, I think one of the top 3 choices on the market. :thumbup:
atvalaska
  • 907, no vacancy !
« Reply #3 on: July 28, 2014, 09:58:45 AM »
it's a azz kicker to bend   imo   just peeling it is no fun.....
« Reply #4 on: July 28, 2014, 06:44:02 PM »
When we did my cousins thermopex we took my 18 volt circular saw and set the blade just deep enough to go thru the outer cover, went around it then made four slits the length wise, piece of cake to peel it off.
Vincent Paul
  • OWF Model: 7500
« Reply #5 on: August 07, 2014, 09:59:31 AM »
Where did you purchase your Thermo Pex?  Cost?  Thanks in advance.
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
Cabo
  • OWF Brand: P & M
« Reply #6 on: August 07, 2014, 04:38:01 PM »
I did mine the same way Mlappin.  I used a Fien multi tool, 4 long cuts, once around pipe and finished.
atvalaska
  • 907, no vacancy !
« Reply #7 on: August 20, 2014, 10:27:58 AM »
painted the inside of my walk in freezer ...brite white....running some lights and getting started !!
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #8 on: August 20, 2014, 12:25:30 PM »
Man, I hope you have some serious ventilation in there!!  You're going to be smoked out every time you open that door!
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
atvalaska
  • 907, no vacancy !
« Reply #9 on: August 20, 2014, 02:39:01 PM »
I have a draft hood with a exhaust fan to in stall ...along with some "make up air"  lol
