Pages: 1 2 3 [4] 5
Author Topic: My logsplitte build. With pics as i go.  (Read 34615 times)
stewie3500
  • OWF Model: C375
Re: My logsplitte build. With pics as i go.
« Reply #45 on: October 18, 2014, 06:27:43 AM »
I finished the outfeed table.
Ram 4500 C&C
Load Trail 14k dump trailer
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #46 on: October 18, 2014, 06:29:58 AM »
Mounted the engine and started plumbing.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #47 on: October 19, 2014, 06:25:35 AM »
Finished the plumbing and routing the hoses.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #48 on: October 19, 2014, 06:30:53 AM »
The two spool hydraulic valve i ordered had the detent located on the opposite end of the spool for the main cylinder. To resolve the issue i mounted the control handles upside down. I also shortened the handle for the wedge lift.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #49 on: October 19, 2014, 07:30:06 AM »
The build is coming to an end. I will fill it with hydraulic fluid and check for leaks. Hopefully tomorrow i can try it out. I will post some pics of the progress, and of course, any modification it requires. The next step is to modify a grain elevator to load the split wood into a dump trailer.
Thanks for the views and the feedback.
Stewie
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
sceptre74
  • OWF Model: BL 28-40
« Reply #50 on: October 19, 2014, 08:11:11 AM »
Looking good. Job well done
stewie3500
  • OWF Model: C375
« Reply #51 on: October 26, 2014, 06:33:11 AM »
So, The trial run of the splitter went well as far as its function is concerned, however, it revealed one weakness. The axle was built from 2" SCH 40 Black iron pipe and proved to be far too weak to support the weight of the machine on a rough gravel road. Here is a pic and the repair that followed.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
« Reply #52 on: October 26, 2014, 06:35:19 AM »
OOPS!
stewie3500
  • OWF Model: C375
« Reply #53 on: October 26, 2014, 06:37:14 AM »
I cut the spindles off the pipe and welded them in the center of 1/2'' plate.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #54 on: October 26, 2014, 06:39:29 AM »
Then,
I attached the 1/2'' plate to 3/8'' x 3" box tubing.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
stewie3500
  • OWF Model: C375
« Reply #55 on: October 26, 2014, 06:51:43 AM »
The four way wedge splits as i had hoped and the outfeed table catches wood. I will post pics of it splitting with the conveyor in place as soon as the conveyor is finished.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
cando attitude
« Reply #56 on: November 09, 2014, 07:36:42 PM »
Very nice build there Stewie.  I really appreciate you taking the time to share your project with us and posting pics along the way.  I also really like the wood catch table you built for it.  Makes me want to try to modify mine in a similar fashion.  Currently I split and grab quickly so the pieces don't fall off on my toes.
 :thumbup:
Echo CS 400
Jonsered 2255
Case 35B
Dirty hands splitter
2013 3500 Duramax
mildot1
« Reply #57 on: November 27, 2014, 05:35:18 AM »
Super Job! Your attention to detail and design is better than factory.  Was wondering if you would share what you used for motor and pump and if you did achieve the cycle time you expected?
« Reply #58 on: November 27, 2014, 05:45:20 AM »
I had an old ear corn elevator that we used to handle firewood when I still had a firewood processor. First thing we had to do was replace the bottom section of the elevator where the wood landed as the this sheetmetal gave way very shortly, replaced it with a piece of 10 gauge, then we took some 3/8 rod, placed a ninety degree bend in one about two inches long and ran that thru a small piece of black pipe. then let the long end hang down and contact the floor of the elevator, did this so a small piece couldn't slip down into the boot of the elevator and jam the paddles when they came around. I can snap a picture of it if you want as i still have the elevator, used a slow running hydraulic motor to run it.
stewie3500
  • OWF Model: C375
« Reply #59 on: November 27, 2014, 07:02:01 AM »
mildot1,
Thanks for the comments, I used a honda gx 390 that i picked up used from a pressure washer setup that was not properly winterized. I paid $50 for it. "Right place at the right time". The pump is a barnes haldex 22 gpm two stage. The cycle times are very close to what i had originally figured. I set the rpm @ 3600 and the use of straight fittings vs 90's helped with the flow and heat. I have since changed the design of the 4 way wedge and will post pics when i get time. The original design was made with 1/2'' plate and was not strong enough. It finally showed its weakness on knarly maple. I made the new wedge with 3/4'' plate and tripled the height where the horizontal wings attach. I also made the new wedge "float" instead of being fixed to the hydraulic ram.
This gives the wedge the ability to rise and fall as need be if the wood is not straight grained or is knotty. Pics help tremendously i know but i have been busy.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
Pages: 1 2 3 [4] 5
