Author Topic: Basement fill valve  (Read 8173 times)
oaky
  • OWF Model: BL-2840
Basement fill valve
« on: July 20, 2014, 06:22:50 PM »
Is it better to locate the fill valve on the supply line or return line? I want to place it onto the 1 inch line where it enters the inside basement wall.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
Re: Basement fill valve
« Reply #1 on: July 21, 2014, 06:40:35 AM »
Should not really matter; but I would personally locate it so that if it leaks or you need to drain boiler; it will not make an utter mess all over
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #2 on: July 22, 2014, 10:35:52 AM »
Doesn't matter unless u have check valves even then u can still do it with some experience
Michigan Thumber
oaky
« Reply #3 on: July 22, 2014, 10:55:44 AM »
Thanks, what about an inline sediment filter? Supply or return for the filter?
Husqvarna 272
Husqvarna 55
LittleJohn
  • Lonsdale, MN
« Reply #4 on: July 24, 2014, 06:43:34 AM »
On my set up I would put the sediment filter on the OWB Supply (Hot) side; but that is only because I run thru a FPHX, then out to radiant slab, and FPHX are very unforgiving if you get them packed full of STUFF
  However if you are not running thru any kind of heat exchanger, I dont think it really matter where filter is put
oaky
« Reply #5 on: July 24, 2014, 08:40:37 AM »
Thanks Little John, since it doesn't matter, I'll place it on the supply line before the HX's.
Husqvarna 272
Husqvarna 55
LittleJohn
  • Lonsdale, MN
« Reply #6 on: July 25, 2014, 06:40:20 AM »
ALWAYS BEST IDEA  ;D, to put a filter/strainer before you go into a HX, lessens chance of crud getting into HX and plugging it
