Author Topic: need help with pump selection  (Read 8437 times)
12valve
  • OWF Brand: P&M
  • OWF Model: BL-3444
« on: July 29, 2014, 08:44:07 AM »
I have about a 100' run from my boiler to my indoor boiler, flat ground, 1 inch id pipe, 4 elbows, and I have no idea what I need for a pump.  Can anyone help me out.
Re: need help with pump selection
« Reply #1 on: July 29, 2014, 08:49:31 AM »
I prefer the Grundfoss 26-99 three speed cast Iron, set the speed to your heat load on temp differential!
12valve
  • OWF Brand: P&M
« Reply #2 on: July 29, 2014, 09:03:20 AM »
Thanks Slim.  So start it out slow and if I am noticing a need for more heat in the house turn it up.
« Reply #3 on: July 29, 2014, 10:52:25 AM »
You've got it, this is where the temp gauges come in handy on all 4 ports, ideally you can keep temp differentials under but close to 20 degrees across the heat exchanger supply and return under full load.
12valve
  • OWF Brand: P&M
« Reply #4 on: July 29, 2014, 11:49:28 AM »
Slim which 4 ports are you talking about?  ON my system I have one 60 plate heat exchanger that handles all of the heat transfer.
« Reply #5 on: July 29, 2014, 11:52:53 AM »
Slim is talking about the 4 port on your 60-plate HX.  So you can moniter Supply and Returns for both Radiant system and OWB ;D
12valve
  • OWF Brand: P&M
« Reply #6 on: July 29, 2014, 11:57:15 AM »
OK thanks LittleJohn.  That is what I was thinking, just wanted to make sure.
« Reply #7 on: July 29, 2014, 12:31:15 PM »
Thanks Littlejohn, I'm busy welding up this darn boiler/ burning myself up and didn't see the post
