Author Topic: Low temp aquastat  (Read 10042 times)
american-pacemaker
  • OWF Brand: P & M
  • OWF Model: OPTIMIZER 250
Low temp aquastat
« on: August 06, 2014, 08:32:17 AM »
Hey SlimJim on my 250 install you said to plumb in an aquastat for low temp shut down of the blower fan. Where should this be plumbed in and how do I wire it in the back of the boiler? Also I am hooking up the supply to the top of the boiler and the return to the bottom of the boiler do you use the connections on just one side of the boiler or one from each side ?
Re: Low temp aquastat
« Reply #1 on: August 06, 2014, 11:18:57 AM »
I like to stagger the connections for better circulation, the aqua stat gets strapped to the supply, I'll send you a picture of it on Cabo's boiler we are just finishing up on it
american-pacemaker
  • OWF Brand: P & M
« Reply #2 on: August 06, 2014, 12:16:16 PM »
Thanks Slimjim
« Reply #3 on: August 06, 2014, 01:35:42 PM »
Here you go, where the brown wire comes back from the safety switch to the junction box and connects to the 2 black wires that go to the blower and actuator, seperate the brown from the 2 black, the brown goes up to the R terminal of the aqua stat and the 2 blacks to the W terminal, set the aqua stat @ 160, this kills the blower and actuator at below 160 degrees, you can also wire a 60 minute timer in parralel to bypass the aqua stat, hopefully you will excuse the mess, we haven't put it all back together yet.
« Reply #4 on: August 06, 2014, 01:39:26 PM »
I know, fire hazard inside a wooden shed! Cabo says he's going to put up a metal shield, You guys please keep on him till he gets it done OK
american-pacemaker
  • OWF Brand: P & M
« Reply #5 on: August 07, 2014, 06:29:50 AM »
Thanks for the pics. I don't mean to sound dumb but why would you need to over ride the second aquastat with a timer ? The install looks really nice.
« Last Edit: August 07, 2014, 06:33:34 AM by american-pacemaker »
« Reply #6 on: August 07, 2014, 06:33:54 AM »
Simply to bypass it when re firing the boiler, I used to simply explain how to reset the aqua stat but then the home owner would forget to reset it after the temp came back up, the timer simply makes it easy and eliminates those oh crap moments
american-pacemaker
  • OWF Brand: P & M
« Reply #7 on: August 07, 2014, 06:38:24 AM »
Oh OK now that makes perfect sense. Thanks
I would like to post pics of my progress but when I try to post it tells me my pics are to many megs and I cannot get them to resize.
« Last Edit: August 07, 2014, 06:40:37 AM by american-pacemaker »
« Reply #8 on: August 07, 2014, 06:41:33 AM »
You are more than welcome, give me a call if you need part #s, I'm sure that Bell Simons in Albany has them on the shelf if you need.
american-pacemaker
  • OWF Brand: P & M
« Reply #9 on: August 07, 2014, 07:05:45 AM »
Will a SPDT 60 minute timer work ? Is a Honywell # L6006C1018 the right one ? That is a HI/LOW limit SPDT aquastat.
« Reply #10 on: August 07, 2014, 07:31:03 AM »
Yes and yes
american-pacemaker
  • OWF Brand: P & M
« Reply #11 on: August 11, 2014, 05:21:25 AM »
Would you go above the stainless damper box and then down to the return on the right side or under the box ? Should there be temp gauges on both lines at the back of the boiler and at the heat exchanger also ?  We had talked about putting a Y strainer before the
heat exchanger and you said to add a bypass. Would going to a 1 1/4 or 1 1/2 strainer eliminate the need for a bypass ? The 1 1/4
is rated for 8 gpm and the 1 1/2 is 10 gpm.
Thanks
« Last Edit: August 11, 2014, 05:36:29 AM by american-pacemaker »
« Reply #12 on: August 11, 2014, 06:03:51 AM »
Yes I would go above the stainless box, Yes I like to put temp gauges on supply and return, and yes I would still put in the bypass because folks forget to clean it and if it plugs without you realizing it, the circulator could be damaged.
american-pacemaker
  • OWF Brand: P & M
« Reply #13 on: August 11, 2014, 06:27:57 AM »
Ok thanks. I am trying to get all the outside stuff done on the boiler so if the weather turns to crap before the inside is done I will
be ok.
« Reply #14 on: August 11, 2014, 06:30:30 AM »
Good Idea! the temps here on the coast are supposed to plummet this week!
