Author Topic: Somewhat passively, and inefficiently heating a pool  (Read 10704 times)
terpjr
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« on: August 11, 2014, 01:46:36 PM »
Just bought a used 15' above ground pool as a temporary solution to the sheer expense of an inground...
living in upstate NY, wouldn't mind a little boost to my water temp every now and then, keep the wife happy...want to keep my expense to a bare minimum.
Woodmaster 4400 plumbed with 1" pex to a heat exchanger in the basement.
Here is my thought:
Put a T and a shut off valve in each line at the back of the furnace.  After the valve put a 1" or 1 1/2" hose fitting after the valve.
When spring and fall hit and my house is not needing my furnace going full blast all day, hook up enough hose to run from the exit at the backof the furnace, into the pool, run a few rings inside the pool and send it back to the return line...So...bypass my heat exchanger and radiators for a few hours each day
figure 180 degree water circulating in a hose inside the pool will jump it a few degrees and it will only cost me a few pieces of firewood each day.  Boiler would be running anyway...
When I am done, roll the hose up until the next fall/spring.
What is the major flaw with my plan?  Thoughts?  Concerns with materials?
Steve Terplak - Upstate NY
Woodmaster 4400
Husqvarna 562xp, 460 and 261
Massey Ferguson 165, 265, 1080, 40B backhoe, Landini 105 and JD 450B dozer.
Homemade 3pt hitch splitter.
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Somewhat passively, and inefficiently heating a pool
« Reply #1 on: August 11, 2014, 02:16:32 PM »
First thought, make sure you have temperature gauges.  Without having a firm control on your heat loss, you'd want to monitor it so your return temps don't drop too low and "shock" your stove.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
terpjr
  • OWF Model: 4400
« Reply #2 on: August 11, 2014, 02:50:01 PM »
Thank you CountryBoy...
That is a agood point...
what type of return temps could shock system?
Woodmaster 4400
CountryBoyJohn
« Reply #3 on: August 11, 2014, 03:27:56 PM »
The conventional wisdom around here is 145 degrees minimum.  At this temperature, condensation can form inside the firebox at the back where the water returns.  Most guys run 170-180 with a 20 degree delta T for their return temps for a minimum of 150.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
« Reply #4 on: August 11, 2014, 06:01:49 PM »
Real temp gauges will tell you a lot, 20 degree differential is about all you want between supply and return to your OWB, good call countryboy
