Author Topic: thermostat ?  (Read 7543 times)
1ELVIS
  • OWF Model: 2000
  • The devil drives a propane truck
thermostat ?
« on: August 20, 2014, 09:55:49 AM »
I've been playing around with my new boiler getting it rdy for winter and I don't see how to change the temperature differential. Stock it's @ 180 with a 9 degree dip. I'm guessing that's fine but I see some of you run a 7 degree dip and I might want to try that as I learn my heating demands and burning habits
« Last Edit: August 20, 2014, 09:59:30 AM by 1ELVIS »
Echo 450
Echo 370
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Re: thermostat ?
« Reply #1 on: August 20, 2014, 05:55:56 PM »
I left mine the way Craig had it set up and it worked out good.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Chicken farmer
  • OWF Model: 2000
Re: thermostat ?
« Reply #2 on: August 22, 2014, 04:52:16 PM »
I see alot of guys running to 195 deg. Is that the norm for one of these boilers? Was thinking I might need that kind of heat for radiant floor.
Midwestern Ohio
Re: thermostat ?
« Reply #3 on: August 23, 2014, 04:56:11 AM »
CF, each boiler is a bit different, you should run it as recommended by the manufacturer, I suggest that our boilers and pretty much any steel boiler should be run as hot as it can without steaming off, some can go 195 without visible steam, I am not sure I would suggest that with a stainless unit, if a stainless unit runs low on water down below the crown point of the firebox and then gets refilled with water, the quick cooling could crack the unit.
golffanman
Re: thermostat ?
« Reply #4 on: August 31, 2014, 07:15:09 AM »
Elvis........the owners manual is on the Ridgewood Website. Section 4 page 18 explains how to adjust the differential on the stove. It's not a big deal to set and comes in handy when the outside temperature swings. Hope this helps.
Huskee 22 Ton Splitter
Husqvarna 450 Chainsaw
