Author Topic: How deep does insulated pipe need to be burried?  (Read 26106 times)
AirForcePOL
  • OWF Model: G400
« on: August 27, 2014, 10:16:49 AM »
I'm getting ready to dig up my existing pipe and replace it with rehau foam filled pex.  My question is, how deep does it need to be?  I have a lot of rocks and concrete chunks and all kinds of other stuff burried in my yard.  My existing pex is burried about 18 inches.  I was hoping that I could just dig that up and put the new stuff in the same trench so I don't have to worry about hitting any more chunks of concrete by going deeper.  Will this be deep enough?
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
fraizer1
  • OWF Brand: woodmaster
  • OWF Model: 434
Re: How deep does insulated pipe need to be burried?
« Reply #1 on: August 27, 2014, 05:03:13 PM »
i replaced my underground line this spring. replaced it with thermopex. dealer i got it from said 18 inches would be just fine.
live in north central ohio, burn 10 cord of wood, had furnace 13 years
« Reply #2 on: August 27, 2014, 05:22:59 PM »
I as well would think 18" should be fine. We run 30,000 lb combines over plastic drainage tiles that barely have 18" of cover on them and haven't crushed one yet.
« Last Edit: August 27, 2014, 09:51:40 PM by mlappin »
« Reply #3 on: August 27, 2014, 06:25:06 PM »
Well if you never had a problem with your existing pipes being that shallow..I don't see a problem..But if you plan on driving over them..I def go deeper..
« Reply #4 on: August 27, 2014, 06:29:05 PM »
My house run is down 6 ft due to running under the main road. My shop loop is out in the open, nothing covering it. Of course this will be the first year.
AirForcePOL
  • OWF Model: G400
« Reply #5 on: August 27, 2014, 07:17:17 PM »
Cool thanks guys.  I won't be driving over it I just was wondering if my current depth would be acceptable.  Thanks again!
Athens, Illinois
Stihl MS 290
« Reply #6 on: August 27, 2014, 09:54:32 PM »
Depends on what you're going to drive over it. The occasional car, pickup, or utility tractor? 18" is fine. We have several 4" drainage tiles buried under the main drive by the grain pit, not more than 3' deep. Routinely gets 80,000lb plus semi's over it and the tiles haven't collapsed yet. Logstor or it's equivalent is much tougher than a standard perforated 4" drain tile.
sceptre74
  • OWF Model: BL 28-40
« Reply #7 on: August 28, 2014, 04:56:16 AM »
Hey Slim, what's your take on this? Getting ready to bury mine very soon
« Reply #8 on: August 28, 2014, 05:22:50 AM »
In all honesty sceptre, put it as deep as you like, I have NO concern about crushing the Logster, I have purposely driven over a scrap piece in my gravel driveway with my 416 CAT with a full bucket, it did not damage the pipe.
sceptre74
« Reply #9 on: August 28, 2014, 05:29:10 AM »
Wow. Sounds like it can take a beating. Thanks
AirForcePOL
  • OWF Model: G400
« Reply #10 on: August 28, 2014, 07:16:25 AM »
Does burrying it deeper have much effect on efficiency?
Athens, Illinois
Stihl MS 290
« Reply #11 on: August 28, 2014, 07:27:46 AM »
Bury it deep enough and you should get away from the frost, but however might get into soil thats wet all the time.
« Reply #12 on: August 28, 2014, 07:38:12 AM »
I agree with Slim, put the pipe as deep as you like.  Up hear in the great WHITE NORTH (Minnesota) we like to put it below frost line if possible, but really unless you are melting snow over your lines or your delta T is huge, I see no issues.
However it might be nice to drop the ends, so it comes up more vertical due to min bend radius of insulated pipe
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #13 on: September 02, 2014, 11:04:45 AM »
Many pipes get their rated crush strength only when buried , like simple drain tile has a 3000psi crush rating, but only when buried.
18" is fine many are 12" like septic lines. I'd only go deeper if you knew is was dry all the time.  You'd have to deep enough to maintain above freezing conditions 24/7 to see a gain, and really deep,  like 6' plus to see a measurable savings or gain. And that's only if its dry all the time.
Michigan Thumber
martyinmi
« Reply #14 on: September 02, 2014, 08:13:32 PM »
I dug up my ThermoPex early this spring and replaced it with 5 wrap from Z Supply.
 Mine was 18" through my yard and 24" under my driveway. (Deeper under driveway because I had a Freightliner FL80 loaded with two pulling tractors and weights driving over it on a regular basis.)
 Thermopex came out just as round as it was the day I buried it.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
