Author Topic: potential problem..  (Read 8275 times)
Hammersquash
  • OWF Brand: Empyre
  • OWF Model: 200 ProHS
potential problem..
« on: September 02, 2014, 02:52:57 PM »
  I cracked open my plenum today to install my heating coil and much to my chagrin there is no room for it under the A coil.
  I have a Brunswick forced air Oil furnace and the A Coil only has about 2" above the peak of the 'A' so I can't raise it to install the water coil.
  Is it a viable solution to install the water exchanger on the cold air return side?
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
2012 F250 King Ranch 6.7 TD
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
Re: potential problem..
« Reply #1 on: September 02, 2014, 03:13:47 PM »
That's what I had to do. I had the same issue.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #2 on: September 02, 2014, 06:20:59 PM »
mine is to.does a good job ^-^
austin qc
bluegrass rules
proud appalachian
Dano
  • OWF Model: ml30
« Reply #3 on: September 05, 2014, 08:57:01 AM »
Mine is in the return after the filter no problems.
AirForcePOL
  • OWF Model: G400
« Reply #4 on: September 05, 2014, 11:06:50 AM »
Mine is also on the return side.  Just make sure you put a filter before the coil and you won't have any issues.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Hammersquash
  • OWF Brand: Empyre
« Reply #5 on: September 10, 2014, 05:14:35 AM »
  Thank you very much to those who responded with the same issue I have.  I ended up making a tight install with a new filter bracket above coil.  I am very happy with the results and it was easier than lifting the house 5" to allow enough room to raise A coil.
A- Coil.  Not a great pic, but inlet side is restricted and there is no room to raise it as I have a 1880 farmhouse with low basement.
https://www.flickr.com/photos/123605823@N05/15011026098/
Pic of coil installed, pre soldering.
https://www.flickr.com/photos/123605823@N05/15174542986/
Another, before filter install.  (don't mind the dirty filters, they are gone now!)
https://www.flickr.com/photos/123605823@N05/15010783399/
Now installed.  Tight fit with new filters.
https://www.flickr.com/photos/123605823@N05/15010996027/
Buttoned up!
https://www.flickr.com/photos/123605823@N05/15010782569/
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
AirForcePOL
  • OWF Model: G400
« Reply #6 on: September 10, 2014, 05:58:41 AM »
Looks good!!
Athens, Illinois
Stihl MS 290
