Author Topic: leaning tree  (Read 9845 times)
trz
leaning tree
« on: September 04, 2014, 05:38:46 PM »
I have a box elder about 10" dia. that's growing at about a 45° angel. How do I go about cutting it down? Would you make a relief cut ( won't the weight immediately pinch the saw)? Or just cut it without relief cut or notch?
dukethebeagle
  • OWF Model: 0001 hot tamali
Re: leaning tree
« Reply #1 on: September 04, 2014, 05:44:36 PM »
just whack it.its gonna go anyway
austin qc
bluegrass rules
proud appalachian
Re: leaning tree
« Reply #2 on: September 04, 2014, 07:11:25 PM »
 I'd still put a relief cut in if only a few inches deep, leaners can do funny things sometimes, like kick right off the stump.
farmboythegreat
  • OWF Brand: freisen
  • OWF Model: 33hd
Re: leaning tree
« Reply #3 on: September 04, 2014, 07:47:53 PM »
notch it  :thumbup:
Muir Ontario Canada
AirForcePOL
  • OWF Model: G400
Re: leaning tree
« Reply #4 on: September 04, 2014, 08:46:45 PM »
Make a small relief cut in the side that's leaning (maybe 2 inches)  Make your final cut on the other side about a inch higher.  Make sure you get enough cut before it starts to fall.  It should snap off once it leans enough.  Just be careful that it doesn't pop up and hit you in the face after it falls.
Disclaimer: I am not a professional unless we're talking about beer drinking.  Cut at your own risk.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: leaning tree
« Reply #5 on: September 20, 2014, 09:07:41 AM »
I cut box elders like that all the time.  Just like others have said you need to make a small bottom cut or notch.  Otherwise it will split and hang up and be hard to saw off not to mention dangerous.  Sometimes they barber chair or spin so watch out.  I cut them at waist height so I can see what is happening and am standing ready to run.
Be careful and have an escape route.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
d conover
  • OWF Model: H4
Re: leaning tree
« Reply #6 on: October 30, 2014, 11:58:19 AM »
I just noticed the post, kind of late...   Do a search on cutting heavy leaner trees, and barber chair like mentioned before.
Leaning trees can be real dangerous.  It is usually recommended to do a plunge cut to relieve the center of the tree. then notch it, then fell it by cutting backwards out of the plunge cut.
I did a terrible job of trying to explain. ???
Anyway I like to got my head took off several years ago by a leaning tree splitting and shooting right back inches from my head.
Southeast Missouri
Hardy H4
044 Stihl
038 Stihl
5100s Dolmar
55R husqvarna
CS301 Echo
Re: leaning tree
« Reply #7 on: October 30, 2014, 01:49:35 PM »
IMO I would not plunge cut a tree at 45o, HELL its half way over only a small relief cut should be required.
I do like the cutiting at waist height if you will be removing stump later, provides leverage
lindnova
Re: leaning tree
« Reply #8 on: October 30, 2014, 02:16:20 PM »
The OP has a 10" tree.  Small notch and back cut.  Plunge cutting is for bigger trees.
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: leaning tree
« Reply #9 on: October 31, 2014, 05:21:42 AM »
Mr. HD5 is correct.  Notch the underside, then plunge up to the hinge, then back towards the back of the tree.  Watch the videos.  This is a dangerous cut.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
farmboythegreat
  • OWF Model: 33hd
Re: leaning tree
« Reply #10 on: October 31, 2014, 06:50:33 AM »
wrap  some C4 around it  and  put a long  fuse   :thumbup:
Muir Ontario Canada
Re: leaning tree
« Reply #11 on: October 31, 2014, 07:14:39 AM »
Length of fuse depends on how fast you can run  ;D
tawilson1152
  • OWF Brand: Crown Royal
  • OWF Model: 7300
Re: leaning tree
« Reply #12 on: October 31, 2014, 07:34:35 AM »
If the stump has to come out too and you have access to a backhoe you can dig the roots out on one side and push it over. I mention this because a box elder that has to come down is often in someone's yard. I took down a couple larger ones in my backyard this summer like this.
