Author Topic: Primary / secondary design  (Read 16961 times)
american-pacemaker
  • OWF Brand: P & M
  • OWF Model: OPTIMIZER 250
« on: September 16, 2014, 08:35:21 AM »
Hey Slimjim I attached a new drawing for my primary / secondary design for the hot water boiler in the house. I could not fit the design of the drawing that I showed you and dan when you stopped at the house because of size limitations. The new design will fit where I need it to. Do you see anything wrong with the design ? Anyone else please feel free to critique the design as I am getting ready to order a lot of copper fittings.
Thanks, Larry
Re: Primary / secondary design
« Reply #1 on: September 16, 2014, 09:39:25 AM »
Nice job, long radius 90's right?
american-pacemaker
  • OWF Brand: P & M
« Reply #2 on: September 16, 2014, 09:45:15 AM »
Yes all the 90's will be long radius. The main tube will be 1 1/2" with 1" on the water heater and 3/4" on all the baseboard.
Should I add a drain valve on the bottom leg of the header do bleed the system or is that a waste of a valve ?
« Last Edit: September 16, 2014, 09:47:06 AM by american-pacemaker »
« Reply #3 on: September 16, 2014, 10:03:29 AM »
Only thing I see is might add a few more T's with caps for future expansion.
american-pacemaker
  • OWF Brand: P & M
« Reply #4 on: September 16, 2014, 10:32:29 AM »
I thought about that the problem is space. Primary / secondary physics says minimum 8x pipe diameter on supply side and 4x pipe diameter on return of each set of tee's which is really cramping me for the space I have. One of the secondary runs in the drawing is an extra that will be
capped of.
« Last Edit: September 16, 2014, 10:52:43 AM by american-pacemaker »
american-pacemaker
  • OWF Brand: P & M
« Reply #5 on: September 16, 2014, 12:38:54 PM »
Should the circulator on the boiler pump into the return or pump into the supply line ? I have been told both.
« Reply #6 on: September 16, 2014, 12:43:38 PM »
Boiler pump? which one oil or wood?  I typically install on the wood boiler supply (top port)?
american-pacemaker
  • OWF Brand: P & M
« Reply #7 on: September 16, 2014, 12:45:15 PM »
Sorry, the pump on the inside boiler.
« Reply #8 on: September 16, 2014, 12:50:58 PM »
If you are doing a primary secondary you really aren't going into the oil boiler,  the return from your primary would be first in the loop and the circ would be installed in the second close T and wired to the c-1 terminal on the aqua-stat.
american-pacemaker
  • OWF Brand: P & M
« Reply #9 on: September 16, 2014, 12:54:06 PM »
Slimjim, in the drawing at the start of this thread I was told by a local guy that my circulator should be on the line going into
the return side of the boiler not where I drew it.
« Reply #10 on: September 16, 2014, 01:07:12 PM »
A lot of the old timers put the circs on the return because the circs back then were thought to not like the temps as well as for space reasons during shipping they were typically installed on the return, in reality it makes no difference, I personally put them on the supply but as long as it is wired to c-1 and done with closely spaced tees, the only water going into and out of the oil boiler is when the circ is energized.
american-pacemaker
  • OWF Brand: P & M
« Reply #11 on: September 16, 2014, 01:12:05 PM »
Thanks !!!!!!
« Reply #12 on: September 16, 2014, 03:28:55 PM »
You are very welcome!
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
« Reply #13 on: September 17, 2014, 06:30:36 AM »
If you get really bored, and don't mind reading a little bit; there is a book out there called "Pumping Away", which helps break down complex radiant installation into plain English
american-pacemaker
  • OWF Brand: P & M
« Reply #14 on: September 17, 2014, 07:07:55 AM »
Thanks Littlejohn I will look for this.
