Author Topic: Solenoid  (Read 9580 times)
jamesbodeis
  • OWF Brand: Ridgewood
  • OWF Model: 7500
Solenoid
« on: September 29, 2014, 07:48:18 PM »
Anyone else's solenoid fairly loud? I dont know how loud they are supposed to be but I have noticed mine humming pretty good a few times now.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
Chicken farmer
  • OWF Model: 2000
Re: Solenoid
« Reply #1 on: September 29, 2014, 07:59:28 PM »
If you were able to measure the frequency of the "hum", it would be 60Hz (60 cycles a second) matching the 60 Hz in the electrical grid. It is possibly due to a damaged/worn shaded pole in the solenoid. The shaded pole is supposed to suppress the "gap" in magnetism of the coil as the AC sine wave passes through 0 VAC either on the ramp up from the negative or down from the positive side. What you are hearing is common to AC solenoids. I've seen those things last for years chattering like crazy in an industrial setting, but I've seen them burn out pretty quick after they start to chatter. The solenoids are a Grainger part and are not too expensive. I was given a spare when I picked up my stove and plan to always have a spare on the shelf. Hope this helps.
« Last Edit: September 29, 2014, 09:14:45 PM by Chicken farmer »
30 yrs burning wood - new to the boiler scene
Midwestern Ohio
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Solenoid
« Reply #2 on: September 29, 2014, 08:42:56 PM »
It's normal to hear a humming.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Chas
  • OWF Model: 6000
Re: Solenoid
« Reply #3 on: September 30, 2014, 09:53:57 AM »
At times mine will hum enough that it causes a vibration. If I tap the little "roof" over the solenoid and damper door it will stop the vibration and quiet right down.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Middle of the mitten, Michigan
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
Re: Solenoid
« Reply #4 on: September 30, 2014, 10:29:23 AM »
Put a few drops of oil on it  will take take the humming noise away
Re: Solenoid
« Reply #5 on: September 30, 2014, 11:11:38 AM »
  Tighten the cotter pin, the loose pin allows the vibration to amplify!
jamesbodeis
  • OWF Model: 7500
Re: Solenoid
« Reply #6 on: September 30, 2014, 01:15:55 PM »
Cool I didnt think it was anything major. Thanks for the replies.
Ridgewood 7500
Jonsered 2260
6pacmac
  • OWF Model: 6000
Re: Solenoid
« Reply #7 on: September 30, 2014, 05:36:58 PM »
Also check the mounting nuts and bolts for tightness.  They like to work loose :)  I lost one that way and all the rest were loose.
Ridgewood 6000
Re: Solenoid
« Reply #8 on: September 30, 2014, 10:06:51 PM »
Also make sure it is fully seated when energized and is moving freely when off. If it is not able to go in all the way it will have a short life.
automan77
  • OWF Brand: ridgewood
  • OWF Model: 6000
  • Just say no to propane
Re: Solenoid
« Reply #9 on: October 01, 2014, 02:31:33 AM »
I spray some lube on mine every couple weeks and it doesn't make any noise.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Re: Solenoid
« Reply #10 on: October 06, 2014, 09:18:41 PM »
Like the others said, the hum is normal. I've had brand new definite purpose contacters and motor starters hum right out of the box, also have a antique one that's been around forever and it's hummed since dirt was new. And yah, they hum at 60 hertz or 60 times a second.
ffbare
  • OWF Model: 6000
Re: Solenoid
« Reply #11 on: October 14, 2014, 08:02:30 PM »
I just replaced my solenoid tonight, I hope this one lasts longer. I have been running for only about a week.
Polk wisconsin.   Husky saws, 27ton husky splitter,  gehl skid, tb016 excavator
