Author Topic: O2 Barrier PEX or NOT??  (Read 8780 times)
cando attitude
  • OWF Model: BL 28-40
« on: September 30, 2014, 05:23:59 PM »
Well, I'm slowly but surely making progress on the install of my new Portage and main 28-40 and I am in the market for PEX at this point and wanted to throw a few questions to you guys who know a whole lot more than I do.  A little about the install: approx. 75' run (Thermopex Brand) of pipe.  In the house, I have a single heat exchanger coming off the air handler and I plan to install a DHW heat exchanger (still trying to decide if I want sidearm or plate-frame).
Questions:
1.)  With corrosion inhibitor in the fluid, is there really a need to buy O2 pipe?
2.)  Does the thermopex pipe that I purchased have an O2 barrier?
3.)  The boiler itself is open to atmosphere and thus is exposed to O2 as well.
By the way, here's a picture of the angst I went through getting the boiler in place
Help!! :-\ :-\
Echo CS 400
Jonsered 2255
Case 35B
Dirty hands splitter
2013 3500 Duramax
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: O2 Barrier PEX or NOT??
« Reply #1 on: September 30, 2014, 06:42:43 PM »
Uponor HePEX is what I'd use.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #2 on: September 30, 2014, 07:52:40 PM »
No need for O2 barrier pipe. Also, I would recommend a plate exchanger over a side arm all day! Easier to install! They only way I would recommend an arm is if you have low usage. Plumb in the 20-plate before your tank and enjoy unlimited hot water!
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
« Reply #3 on: September 30, 2014, 10:03:29 PM »
1.) No, there is no need for it.
2.) Yes, Thermopex has oxygen barrier. (only way that type of pipe is made)
3.) Doesn't look like a question but I agree with it.  :D
« Reply #4 on: October 01, 2014, 06:19:40 AM »
CANDO, the only time you need to run pipe with an O2 barrier is if you are running a closed loop system; because you are trying to limit the amount of O2 that gets absorbed thru the walls of the pipe and into the system.
This is not say that you can't run an O2 barrier, and be fine (...you would be); but most people don't want the extra expense of barrier pipe.
woodbutcher
  • OWF Model: MF10000e
« Reply #5 on: October 01, 2014, 09:10:05 AM »
I used CB's pex on my CB model CL400 boiler when I purchased it and it did not have the oxygen barrier and it failed in 6 years. The new thermpex  that was a replacement for the old pex has an oxygen barrier and it has been in use for over 8 years and no failure. When I replaced the old pex it was as brittle as glass. This has been my experience with pex. I think it is better to go with the oxygen barrier from the start than it is to replace it latter on.
cando attitude
« Reply #6 on: October 01, 2014, 07:28:22 PM »
I appreciate the responses guys.  Thanks for the help.  I'm looking to run my inside lines this weekend, hook up the heat exchanger in furnace and perhaps fire the girl up sometime on Sunday.
On he DHW heat exchanger, I think I've convinced myself to go with a plate type before the water tank.  My gut tells me to go with a 30 plate but I'm also wondering if this is overkill and if a 20 plate would work.  The way I see it, the DHW HX should see incoming hot water around 180 degrees.  I'm hoping to get hot water around 130F.
Echo CS 400
Jonsered 2255
Case 35B
2013 3500 Duramax
« Reply #7 on: October 01, 2014, 07:34:48 PM »
20 plate will make all the hot water you want but may require a larger pump to do it. The 30 will have lower head pressure which will give you more GPM. If the pump is just barely big enough for your system, I would go with a 30 plate.
« Reply #8 on: October 01, 2014, 07:36:49 PM »
Being non barrier was not the reason for the failure. Without seeing it I couldn't say what caused it to fail but if it was the same brand with barrier and handled, installed, etc the same way it would have failed too.
