Author Topic: House penetration  (Read 12925 times)
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
House penetration
« on: September 30, 2014, 07:02:41 PM »
How did you all route your pipes into your houses? Also what type of pipe did you use?
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: House penetration
« Reply #1 on: September 30, 2014, 07:54:46 PM »
I used an upsidedown roof flange to get in my garage then through my breezeway void in the attic.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
« Reply #2 on: September 30, 2014, 08:04:30 PM »
I cut a 4in hole in my foundation  iam useing  cb  insulated pex witch is 3 in and I mixed up 2 bags of quick cement and filled the space and dump the rest on top not a drop of water I think iam going on my 5 the year
Jwood
« Reply #3 on: September 30, 2014, 08:10:37 PM »
My house is an enercept home so I don't think I want to come in below grade, me and slim talked about coming up to above grade before I enter the house then building a dog house.
Stihl MS 270c
Stihl MS 461
CountryBoyJohn
« Reply #4 on: September 30, 2014, 08:28:36 PM »
This is essentially what I did. But, the flange is much more weather proof than a doghouse wooden structure. I'll try to post a picture tomorrow.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Jwood
« Reply #5 on: September 30, 2014, 08:42:06 PM »
Thanks country boy now this is an idea from my dealer.
Stihl MS 270c
Stihl MS 461
« Reply #6 on: September 30, 2014, 09:59:11 PM »
If you do something like that, I would cover the pipe. Most plastic will eventually break down from sunlight. They don't even recommend storing drain tile outside for extended periods of time and I would be surprised if it was any different for Thermopex or Logstor. Same with PEX, if you need to store it or run it outside, keep it covered or shaded if it will be out for more than a few weeks.
Jwood
« Reply #7 on: October 01, 2014, 04:03:47 AM »
 :post: RSI, I don't have my route totally figured out yet.
Stihl MS 270c
Stihl MS 461
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
« Reply #8 on: October 01, 2014, 06:15:11 AM »
It probably doesn't help but I went under-footing and came up thru floor -> I also did this before all the cement was poured
I do like image that jwood posted.
In regards to PEX and sunlight, a definate NO-NO; must keep stored out of direct sunlight.
« Reply #9 on: October 01, 2014, 06:37:25 AM »
Just paint over the plastic and Logstor to match the color of the house.
CountryBoyJohn
« Reply #10 on: October 02, 2014, 05:26:28 AM »
Here are the roof flange pictures.  I used silicone to seal things up nice.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Jwood
« Reply #11 on: October 02, 2014, 05:40:56 AM »
Thanks for the pictures country boy!
Stihl MS 270c
Stihl MS 461
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
« Reply #12 on: October 03, 2014, 03:09:18 PM »
I did the same thing.  If I was installing after the house was up & would core thru the foundation wall below grade and find a way to pipe it thru the house.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
« Reply #13 on: October 07, 2014, 08:28:03 PM »
Looked into those, can't touch one of those 4" boxes for less than a hundred bucks a piece.
Jwood
« Reply #14 on: October 07, 2014, 08:31:10 PM »
Oh wow! That's spendy!
Stihl MS 270c
Stihl MS 461
