Author Topic: Sharkbite guages  (Read 16484 times)
AirForcePOL
  • OWF Model: G400
Sharkbite guages
« on: October 02, 2014, 09:17:32 AM »
Has anyone used these guages before?  It seems pretty cheap for a Sharkbite fitting.
http://www.altheatsupply.com/shop-by-needs/outdoor-wood-furnace-parts/thermostats-gauges/sharkbite-pressure-gauge.html
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Steinacher Sales
Re: Sharkbite guages
« Reply #1 on: October 02, 2014, 10:07:15 AM »
Airforce,
These are pressure gauges that you are siting, an open system will not show much pressure I would not think. The temp. gauges are a lot higher. The 1" is around $40.00!
Greg Steinacher
618-401-0726
www.midwestoutdoorfurnace.com
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #2 on: October 02, 2014, 10:56:26 AM »
I have a 1" temp gauge  I think it was 35 or 40.  Shark bite
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
AirForcePOL
  • OWF Model: G400
« Reply #3 on: October 02, 2014, 12:08:55 PM »
ooops you're right thanks.  What is the cheapest way of installing a temp guage other than a strap on?  I have a strap on but i just feel like you dont get the most accurate readings with it.
Athens, Illinois
Stihl MS 290
« Reply #4 on: October 02, 2014, 01:45:14 PM »
Use a little of that paste like you use on the cooling fans for the CPU in a desktop.
AirForcePOL
  • OWF Model: G400
« Reply #5 on: October 02, 2014, 01:48:12 PM »
I used some of that on the one i had.  I think I'm just going to buy one or two of the meat probes and put that paste on them and tape them up real good.  Wireless monitoring would be preferred anyway.
Athens, Illinois
Stihl MS 290
automan77
« Reply #6 on: October 02, 2014, 03:05:09 PM »
Supply house.com has the temp gauges
Scott K
Stihl ms 311
Husky 455
« Reply #7 on: October 02, 2014, 09:33:08 PM »
 I've used those on infloor heat jobs and they worked really well. It allows me to adjust my mixing valve to exact temps as needed.
WoodMOJoe
« Reply #8 on: October 06, 2014, 07:06:06 AM »
Great idea, gonna give that a try when I install my wireless bbq probes in a month or so.  Think I already have a tube of it.   :thumbup:
AirForcePOL
  • OWF Model: G400
« Reply #9 on: October 06, 2014, 07:51:01 AM »
That's my plan too.  I just bought two of the meat thermometers on Amazon for $34 each they are the Maverick ET-73 model.
Athens, Illinois
Stihl MS 290
GCTerpfan
  • OWF Model: Classic
« Reply #10 on: October 06, 2014, 09:37:52 AM »
Are the wireless BBQ thermometers battery operated?  Do you plan on letting them on 24/7?  How long do you think the batteries would last if you do?
It seems like a "pretty slick" and cheap alternative if you don't end up replacing batteries every week.
Garrett County, MD
AirForcePOL
  • OWF Model: G400
« Reply #11 on: October 06, 2014, 09:40:07 AM »
Yea they are battery operated.  Someone on this site said the batteries will last a while.  Like a year or two.  We will see.
Athens, Illinois
Stihl MS 290
GCTerpfan
« Reply #12 on: October 06, 2014, 10:00:13 AM »
I might have to give this a try.  The one you listed has two probes, so you could monitor the supply and return temps at the same time.
Garrett County, MD
AirForcePOL
  • OWF Model: G400
« Reply #13 on: October 06, 2014, 10:12:20 AM »
yep.  It's perfect for monitoring both temps.  I'm not sure what the accuracy will be when measuring the temp through pex but the difference should be the same if the temp is measured off of the same type of surface on both probes.  It should do a good job at measuring what the difference is in the supply and return lines.  Here is a link to the ones I bought.  http://www.amazon.com/Maverick-Remote-Smoker-Thermometer-ET-73/dp/B00EQFFOLA/ref=sr_1_5?ie=UTF8&qid=1412611358&sr=8-5&keywords=maverick+et-73
Athens, Illinois
Stihl MS 290
smitty33
« Reply #14 on: October 06, 2014, 04:47:33 PM »
I have the maverick wireless set up on mine. Works great.  Make sure the probes are on copper or some kind of metal. It will not read correct on pex. Batteries on mine last about 6 months. Also has Hi and low alert.
