Author Topic: quick question  (Read 6856 times)
gainerspot
  • OWF Brand: P&M
  • OWF Model: Ultimizer BL 2840 (soon)
quick question
« on: October 03, 2014, 12:20:13 AM »
Can I T off from my logstor and run one line to DHW and the other to the Water to Air exchange, or does it need to be a single loop?
I have been using this formula to figure the head loss.  I cant seem to come up with any info on how to calculate for the heat exchanges.  Any info on this would be helpful.
http://www.taco-hvac.com/uploads/FileLibrary/SelectingCirculators.pdf
« Last Edit: October 03, 2014, 03:00:39 AM by gainerspot »
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
Re: quick question
« Reply #1 on: October 03, 2014, 06:35:49 AM »
A drawing or sketch would really help...
If you were using a FPHE, I would definately recommend put it in as a secondary loop, as they can have very high head pressures.
Since water to air exchangers have less restrictions you may be able to put in primary loop, but I have never installed a water to air exchanger, so...
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: quick question
« Reply #2 on: October 03, 2014, 06:52:18 AM »
I have a 20 plate DHW flat plate and a 60 plate exchanger inline and no problems.  I did install valves and bypass for problems or maintenance.  On the 20 plate I leave the bypass valve partially open so some bypass can happen and prevent back pressure.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
Trint
  • OWF Model: ml 30
Re: quick question
« Reply #3 on: October 03, 2014, 10:19:32 AM »
Yes you can that how I have mine, just put a valve in the line to the dhw so you can control the flow between the two.
North Central Ohio
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: quick question
« Reply #4 on: October 03, 2014, 01:01:48 PM »
That will only work if you have a pump on each run.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
