Author Topic: Indoor boiler question  (Read 13531 times)
12valve
  • OWF Brand: P&M
  • OWF Model: BL-3444
« on: October 05, 2014, 07:39:40 AM »
I know some of you are experts on this......  My indoor boiler which is heated via my p&m 3444 is giving me problems.  First issue is my pressure gauge is reading 39 psi at 180 degrees.  I think from what I have read that is to high?? Also The only way I can get it to pump water to my upstairs zones is to have my pump on level 3 (high).
Any thoughts?
Re: Indoor boiler question
« Reply #1 on: October 05, 2014, 09:14:30 PM »
  Wow, I just saw this, Yea buddy it's too high, something is wrong, let's talk in the AM
12valve
  • OWF Brand: P&M
« Reply #2 on: October 06, 2014, 07:04:45 AM »
The 2 things I can think slim.
I have a blockage or partial blockage somewhere in my baseboard heat.  Or I need to replace the airscoop, valve and expansion tank???  But those are just guesses.
« Reply #3 on: October 06, 2014, 07:13:28 AM »
First of all 12 valve is that the pressure relief valve should have popped long before that pressure, why did it not? is it functioning?
12valve
  • OWF Brand: P&M
« Reply #4 on: October 06, 2014, 07:15:15 AM »
I don't know????  That is why I am here?  It is an old boiler,  But I am just using it for the pump and the thermostat that are built into it.
« Reply #5 on: October 06, 2014, 07:24:55 AM »
Could you send some pictures to my E-Mail?
12valve
  • OWF Brand: P&M
« Reply #6 on: October 06, 2014, 07:29:14 AM »
Sure.  I am at work right now but I can later on.  What would you like to see.
« Reply #7 on: October 06, 2014, 10:48:54 AM »
Near oil boiler plumbing!
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #8 on: October 09, 2014, 07:22:09 AM »
T&P gauges should be replaced often, the reading is more likely wrong. It's more likely the gauge is wrong than PRV being stuck. Both should be replaced every 5 yrs or sooner if they fail a test.
By the way was that pressure reading while the pump was on high, or is the gauge close to the pump? There are a lot of variables as to why you have no circulation upstairs. The pump speed should ONLY, control GPM. Not whether it actually flows at all. If their are no checks or zone valves stuck there should be gravity flow atleast, unless there is a heat trap.
Michigan Thumber
12valve
  • OWF Brand: P&M
« Reply #9 on: October 09, 2014, 01:16:54 PM »
Sprinter I sent you a PM.  The pressure gauge I am looking at is built right into the boiler.
fryedaddy
  • OWF Model: 750 Gallon
« Reply #10 on: October 09, 2014, 01:22:58 PM »
I doubt the guage is built in, it's probably a threaded guage in a sensor well.
I could easily be wrong though
12valve
  • OWF Brand: P&M
« Reply #11 on: October 09, 2014, 01:29:16 PM »
That's possible Fryedaddy.  I haven't messed with it.
Big Wood
« Reply #12 on: October 09, 2014, 05:46:57 PM »
Was a plate exchanger used to separate the two boilers if so you could cut in a tee with a new well for a new gauge so you don't have to mess with your old boiler  also sounds like trapped air possibility try a good purging on the lines crack the flange on the circulator to see if it is air bound just some more info
