Pages: [1] 2 3
Author Topic: set temp and differential on the BL series  (Read 23987 times)
12valve
  • OWF Brand: P&M
  • OWF Model: BL-3444
« on: October 07, 2014, 09:23:45 AM »
Hey guys.  Got the BL 3444 running.  All is well.  I was just wondering from people who used them last year about set points and differentials depending on the time of year.  What works best for you guys.  Right now I am at 189 degrees with a 5 degree dif?  When it gets colder I was thinking of opening up the dif to 10 degrees or maybe more?  Does this make sense, what works for all of you?
Re: set temp and differential on the BL series
« Reply #1 on: October 07, 2014, 11:59:13 AM »
How about 195 with a 10 degree differential.
12valve
  • OWF Brand: P&M
« Reply #2 on: October 07, 2014, 12:11:02 PM »
If that's what you recommend that is what I will do.  I am just learning this new system.
« Reply #3 on: October 07, 2014, 12:12:39 PM »
Watch for visible steam coming from the vent tube/water level gauge, if you see visible steam then back it off a little.
12valve
  • OWF Brand: P&M
« Reply #4 on: October 07, 2014, 12:28:22 PM »
Haha wouldn't want to boil off all my water!!!! and the differential, would you keep that at 10 degrees during the fall/spring, and during the winter?
« Reply #5 on: October 07, 2014, 12:34:11 PM »
Sure 10 degrees will be fine.
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
« Reply #6 on: October 07, 2014, 01:30:41 PM »
Run 180f with 10 or 15 differential, I forget; but all of my heat is in-slab or under-floor radiant, so max temperature I actually need is about 140F, after FPHE
« Reply #7 on: October 07, 2014, 01:52:35 PM »
Yes but your radiant should have a mixing valve, the higher boiler temps are for the wood boiler, less creosote, more guaranteed heat to the home, and less oxygen in the boiler water, hotter is better, especially with higher efficiency stoves!
randy_1
  • OWF Model: Optimizer 250
« Reply #8 on: October 07, 2014, 04:03:21 PM »
I run mine 196 with 7 degree diff. From October till April..
Kubota L 3300
LittleJohn
  • Lonsdale, MN
« Reply #9 on: October 08, 2014, 06:51:13 AM »
Yes, I do run FPHX and mix valves inside each structure, so that I am able to maintain a stable water temperature to the slab or under floor; and so that I do not overheat
agriffinjd
  • OWF Model: BL 3444
« Reply #10 on: December 27, 2014, 11:09:29 AM »
Slim,
My dealer recommended 180 SP with a 10 degree differential.  I have a forced air furnace in the house, a hanging heater in the garage (2 separate lines from the back of the boiler), and a 20 plate exchanger for the DHW.  I have a BL-3444.  Should I up the SP to 185?  Will a higher SP result in hotter air coming through the heat ducts throughout the house?   If so, how about 190 for a SP?
Thanks.
U.P. of Michigan
« Reply #11 on: December 28, 2014, 03:35:38 AM »
I like to run all my units as hot as I can, at least 185, watch for visible steam coming from the vent tube, different elevation = different boiling temp. Next would be to watch for temp creeps when the boiler is idling, bad door gaskets, overloading with wood and stuck air flappers are common causes for overheating while the fan is off
FareNorth
« Reply #12 on: December 30, 2014, 10:13:28 AM »
I am with Slim on this one too. Hotter temps have to be better for the boiler long term. These units were meant to run hot for efficiency anyways.
Regarding temps, I have developed a homemade application I have running off a little computer and fairly cheap sensors I have tie wrapped on various connections within my system. It spits back a webpage where I can view it's temps and tracks temp trends. Interesting to see how long it runs between cycles etc. I have a sensor just on my boiler loop. Another on the loop to my forced air and its return. I can see how much heat is being removed as it passes through. I mainly put this together to alert me (via text and/or email) when the temps get too low or too high.
Has saved me a few times when the coal bed was so deep, air couldn't get through and caused temps to drop. Was able to correct it and keep it running without having to go thru the painful process of starting a cold boiler. Another time didn't have the ash pan closed all the way and had temps creep up while idle. Figured it's best to know things early and take preventative action.
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #13 on: December 30, 2014, 10:34:47 AM »
I'm running 185 with a 10 degree differential.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
agriffinjd
« Reply #14 on: December 30, 2014, 12:25:00 PM »
I'm at 187 with 10 diff, going to boost to 190 with 10 diff tomorrow.
Anyone ever do greater than 10 diff?  If the diff was higher, wouldn't you get longer periods of hot burns to help reduce creosote, or would it be too long at a smolder and you could lose the coals or create even more creosote?
U.P. of Michigan
Pages: [1] 2 3
