Pages: 1 [2] 3
Author Topic: set temp and differential on the BL series  (Read 23978 times)
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: set temp and differential on the BL series
« Reply #15 on: December 30, 2014, 07:19:47 PM »
 I'm running 194 with a 12 degree differential. Seems to work good for me. Slim told me before and its been said many times to run it hot, so hot it will be.
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #16 on: December 30, 2014, 08:17:49 PM »
When I ran 190 I had to much temp rise and was triggering my 200 degree cutoff so definitely no point for me to continually hit that temp I'm having much better luck with 185 but every stove is going to be a little different. Stay warm guys!
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Shrek1112
  • OWF Brand: Hawken Energy
  • OWF Model: HE-2100
« Reply #17 on: December 30, 2014, 11:27:17 PM »
I'm at 187 with 10 diff, going to boost to 190 with 10 diff tomorrow.
Anyone ever do greater than 10 diff?  If the diff was higher, wouldn't you get longer periods of hot burns to help reduce creosote, or would it be too long at a smolder and you could lose the coals or create even more creosote?
I would like to know everyone's thoughts on this question as well. Adjusted my HE-2100 to 185/15 today, from 180/20, to see how it burns and the creosote build up or lack there of.
Mid- Michigan (Spartan Country)
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
13 & 15 year old work force
Jwood
« Reply #18 on: December 30, 2014, 11:36:44 PM »
That might work you might be better with 185/10
Stihl MS 270c
Stihl MS 461
sceptre74
« Reply #19 on: December 31, 2014, 04:49:39 AM »
I've been running 195 with a 10 differential since day one. Seems to be working well for me so far
Jwood
« Reply #20 on: December 31, 2014, 06:49:17 AM »
Do you ever watch your aquastat after shutdown I'm just curious if I was the only one with the creep problem
Stihl MS 270c
Stihl MS 461
Crow
  • Eastern Ontario
« Reply #21 on: December 31, 2014, 06:54:52 AM »
 I have watched mine and it does overshoot but only slightly.
Jwood
« Reply #22 on: December 31, 2014, 06:56:47 AM »
Probably my gaskets on the ash and heat exchanger door then.
Stihl MS 270c
Stihl MS 461
sceptre74
« Reply #23 on: December 31, 2014, 07:06:36 AM »
Mine does overshoot a bit like Crow's does. I haven't  had any issues with hitting the high limit as of yet.
Crow
  • Eastern Ontario
« Reply #24 on: December 31, 2014, 07:15:13 AM »
  Do you have the orange silicone gaskets on all three doors Jwood?
Jwood
« Reply #25 on: December 31, 2014, 07:18:33 AM »
No just the loading door  >:(
Stihl MS 270c
Stihl MS 461
Crow
  • Eastern Ontario
« Reply #26 on: December 31, 2014, 07:26:08 AM »
 Mine is the same, but it's last years model. I assumed yours would have had all 3 the same. The rope type on the ash door is very hard and I should get the newer seals for it.
Jwood
« Reply #27 on: December 31, 2014, 08:17:01 AM »
Mine was a unit that had not sold from the previous year so I ended up getting a few hundred off and got last year's price on it. I too will be putting the new gasket on this spring if not sooner.
Stihl MS 270c
Stihl MS 461
Maxnchej
  • OWF Brand: Portage and main
  • OWF Model: Bl2840
« Reply #28 on: January 10, 2015, 08:49:05 PM »
I run at 190 and a diff of ten
Uponthehill
  • OWF Model: 250 & 461 Stihl
« Reply #29 on: January 11, 2015, 06:12:10 AM »
188/8. Used to be 190/10, but since my overheat earlier this year, I start to steam pretty good when I have set at 190. I've tried increasing a few times, but keep getting what I would consider too much steam. Lookers like a pressure cooker bobber when canning beans. 188/8 seems to be my sweet spot. Stay warm..
Pages: 1 [2] 3
