Author Topic: CL5648 rewire question  (Read 8133 times)
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« on: October 09, 2014, 05:41:35 AM »
Hi all, I have a 2004 CB Outdoor wood boiler. The electronic controller is non-programmable for high limit beyond 180, so the max temp I can run my boiler at is 180 and I'd like to bump it to 190-195. I am looking at replacing the digital programmer with a Dwyer or something similar.I am not sure how to wire it in once I remove the old one.
I will include pics of the wiring diagram that came with the 5648 and a pic of the Dwyer TS2 Digital temp switch.
The Dwyer has connections for the probe input (#1 and #2)- I'm guessing those are the 2 wires from the aqua stat.I'm not sure if mine is adjustable or non-adjustable .
#7 and #8 are for power - no problem
I'm confused which wires I connect to #9,#10 and #11.
Any help would be appreciated. Will attach pics later
Re: CL5648 rewire question
« Reply #1 on: October 09, 2014, 05:48:37 AM »
You will want to send power out of the normally open terminals, look at the schematic on the control, typically power would come in on the center of the 3 terminals from your high limit switch and then back out to your blower/solenoid on the right side or normally open terminal
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #2 on: October 09, 2014, 06:02:14 AM »
Richard, I do not have a high limit switch - that was only on the Canadian model.
Reading between the lines, I'm guessing I would feed power to #8-run a jumper from 8 to #10, and then run a  feed to solenoid from #11.
Correct?
Would I connect my aqua stat to #1 and #2? does it matter if it's non adjustable?
Lee
« Reply #3 on: October 09, 2014, 06:04:56 AM »
It sounds right but in order to know for sure I would have to look at the diagram, you might be well off to put a separate high limit on the unit just in case your controller malfunctions
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #4 on: October 09, 2014, 06:10:46 AM »
I'll send you the diagram
« Reply #5 on: October 09, 2014, 06:12:14 AM »
OK, How was your summer, did you retire yet or are you still working? Late start on your install don't you think?
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #6 on: October 09, 2014, 06:18:53 AM »
good summer -
retiring in june
install complete and ready to go from last year. just tweaking the controller. you gave me a phone number of some guy in Wisconsin, I believe, that knew the wiring for what I'm talking about -lost his number
 My cell  signal is terrible here at work, so I will get photos to you asap. Based on what I send you, do you think you could sketch a rough pic of how to wire?
« Reply #7 on: October 09, 2014, 06:56:26 AM »
Sure, no problem with a schematic!
« Reply #8 on: October 09, 2014, 07:05:49 AM »
Could you resend those to my E-Mail, mainlycustomsawing@yahoo.com, the Aqua stat I can read and it would be a jumper from your hot in#8 over to the common #10 and then power out would be #11, the schematic on the boiler I am unable to read on my smarter than I am phone!
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #9 on: October 09, 2014, 07:49:09 AM »
just sent them to your email
« Reply #10 on: October 09, 2014, 07:51:01 AM »
Thanks, I haven't received it yet, my I Pad is slow today for some reason, probably a conspiracy!
heatthefarm
  • OWF Brand: CB
  • OWF Model: 5648
« Reply #11 on: October 09, 2014, 08:03:50 AM »
I emailed them and texted them
« Reply #12 on: October 09, 2014, 08:05:48 AM »
  I got the text but no E-Mail yet, check the address, no E on mainly,   mainlycustomsawing@yahoo.com
