Author Topic: kiln drying  (Read 10192 times)
coolidge
kiln drying
« on: October 14, 2014, 06:43:19 PM »
I had a insulated box I had built a couple years ago, so I decided to hook up my water to air heat exchanger and pump the heat into the box with a half cord of wood inside, weighed a piece of Ash yesterday at 11 pounds, weighed in today at 9.5 pounds. Temp in the box is 170 degrees running of my 250. So far I have only filled the firebox half full three times for a 24 hour burn.   Just playing!
Western Maine
AirForcePOL
  • OWF Model: G400
Re: kiln drying
« Reply #1 on: October 14, 2014, 06:45:12 PM »
I've always wondered about this!  Hope it works out for you
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Re: kiln drying
« Reply #2 on: October 15, 2014, 04:20:19 AM »
Are you running the fan constantly or is it running on temperature coolidge?
coolidge
Re: kiln drying
« Reply #3 on: October 15, 2014, 06:04:23 PM »
Fan is on constant.
Western Maine
AirForcePOL
  • OWF Model: G400
Re: kiln drying
« Reply #4 on: December 02, 2014, 08:58:25 AM »
How did this end up working out for you?
Athens, Illinois
Stihl MS 290
coolidge
Re: kiln drying
« Reply #5 on: December 02, 2014, 06:15:56 PM »
I don't think it would be worth the cost of the wood. It did work, but to go from off the stump to 20%, let mother nature do the work.
Western Maine
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: kiln drying
« Reply #6 on: December 02, 2014, 08:03:18 PM »
I agree with coolidge burning wood to dry wood to be burned just doesn't make a lot of sense to me.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
AirForcePOL
  • OWF Model: G400
Re: kiln drying
« Reply #7 on: December 02, 2014, 09:07:22 PM »
I think if you spent the time and money to build something that would hold the heat it would be worth it.  From what I have read, if you can maintain 160 deg for 4 days you can dry oak from 50% to 20%. It would use a lot of energy but maybe coal would be a good substitute for wood
Athens, Illinois
Stihl MS 290
coolidge
Re: kiln drying
« Reply #8 on: December 03, 2014, 03:57:48 AM »
I had no problem maintaining 160, just not shure if the "core" is 160.  I had stacked my wood is a pallet rack and put the whole thing in the kiln. Maybe cross stacking instead would work better. Not shure if my ventilation was the best. I used a 8" stove pipe vented out the top to my insulated chimney.
Western Maine
mikemike
  • OWF Brand: home made
Re: kiln drying
« Reply #9 on: December 03, 2014, 06:15:56 AM »
U could use a blower off your stack
AirForcePOL
  • OWF Model: G400
Re: kiln drying
« Reply #10 on: December 03, 2014, 07:08:52 AM »
I don't think it should be stacked.  I would say build a crate with metal woven wire type sides on it and just throw it in there.
Athens, Illinois
Stihl MS 290
Homerglide
  • OWF Brand: Orlan EKO
  • OWF Model: Out in the shop - Model 25 gasifier
Re: kiln drying
« Reply #11 on: December 03, 2014, 08:36:58 AM »
Solar kilns are easy and economical. Visqueen or maybe even pallet wrap the bottom, top and all sides with drain holes on the floor. A sunny summer day it will easily reach the 160F temps. If I were to need spring cut oak for the coming season, this is how I would go.
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
coolidge
Re: kiln drying
« Reply #12 on: December 03, 2014, 06:11:30 PM »
Agreed on the stacking part, more work. I will see what I can find for a wire rack in the spring and try a loose thrown batch. I did try the solar kiln thing, wrapped a pallet rack with clear plastic, made a pitched roof with clear plastic. I was getting 140 at the top but ambient at the bottom, again stacked wood.
Western Maine
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: kiln drying
« Reply #13 on: December 05, 2014, 11:22:29 AM »
There is a big wood seller that has a storage unit kind of kiln at his "u-pick up' location.  I saw them loading steel pallet bins and a chimney exhausting at one end.  I haven't seen up close how it works or what he is heating with, but it looks like he is selling a lot of wood.  He was out last year and didn't get many new logs until mid summer, so no time to dry like normal.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
Re: kiln drying
« Reply #14 on: December 05, 2014, 01:54:26 PM »
