Author Topic: BL 28-40 air adjustment slide on blower  (Read 7923 times)
cando attitude
  • OWF Model: BL 28-40
« on: October 19, 2014, 08:14:40 PM »
Well, I finally got my new 28-40 hooked up and am really loving the way my home feels.  I am wondering if perhaps Slim or some of you experienced gents can tell me where the best place for the blower adjustment to be.  Does this in anyway affect the efficiency or burn less/more wood if not adjusted properly.
Thanks guys,
Cando
Echo CS 400
Jonsered 2255
Case 35B
Dirty hands splitter
2013 3500 Duramax
Crow
  • Eastern Ontario
Re: BL 28-40 air adjustment slide on blower
« Reply #1 on: October 19, 2014, 08:23:50 PM »
  Congrats on getting it running Cando. I just fired mine up today and I have it probably 3/4 open. I am not sure if it affects efficiency or not but it does recover quicker opened 3/4 to full open.  I am interested in others thoughts on this though.
« Reply #2 on: October 19, 2014, 10:25:49 PM »
I'm going to take a wild guess here and say with very well seasoned wood you could close the slide down and still get plenty of heat, this would also hold true if you weren't needing the full BTU output of the stove, on less seasoned wood or high loads open the slider up more.
« Reply #3 on: October 20, 2014, 04:55:35 AM »
Mlappin is right, you can close it down a bit for less load and let her rip as the load increases.
« Reply #4 on: October 20, 2014, 05:57:31 AM »
How do you guys feel about the burn? is it cleaner than expected for a conventional stove?do you have another conventional in your area to compare it to?
oaky
  • OWF Model: BL-2840
« Reply #5 on: October 20, 2014, 05:54:01 PM »
I've been running new BL the last three weeks with the blower draft door half open, day temps been in the 50's & some days 60's, I'll more likely open it up fully when day temps get into the 20's.
Slimjim, I would have to say this BL smokes a whole lot less than my old Aqua-Therm, the smoke from the BL smell like smoke, not musty old creosote that I got used to for 14 years, really holds the water temp while idling for hours.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
« Reply #6 on: October 20, 2014, 05:59:06 PM »
THAT'S what I like to hear! Happy heating Oaky!
cando attitude
« Reply #7 on: October 21, 2014, 03:47:37 AM »
I'm still getting used to where the BL likes to run.  Due to the warmer air temps lately (40s at night and 60ish during day), I had the water temp backed off to 170.  I recently bumped the water temp to 185 and increased the differential to 10 (was set at factory default).  This seems to really help the stove burn cleaner and I notice less creosote buildup in the stove.  I think the larger differential allows the stove to really fire up for a while and burn off much more of the buildup.
I do have to say that I am impressed at how this old girl pumps out the heat.  My home is ~3000 ft^2 and another 2000 for the basement.  We have had a few nights dip into the 30s and the stove just seems to idle.  We'll see if I'm singing the same tune when the temp drops into the single digits.
So far, I'm very pleased with this unit.
Echo CS 400
Jonsered 2255
Case 35B
2013 3500 Duramax
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #8 on: October 21, 2014, 05:34:25 AM »
Glad to hear that cando!
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
oaky
« Reply #9 on: October 21, 2014, 07:01:39 AM »
It does help to lessen the creosote build up when the water is set 185+ during these milder days.
Husqvarna 272
Husqvarna 55
« Reply #10 on: October 21, 2014, 08:39:04 AM »
I would love to see a video clip of the BL smokestack at startup, mid-burn, and right before reloading.  Just want to gauge its smoke output versus my neighbors CB 6048.   8)
If no one posts one, I will take some video myself and place it on-line (BL 34-44) within the next 5 weeks or so).  O0 :thumbup:
Jwood
« Reply #11 on: October 21, 2014, 09:07:48 AM »
 :post:
Stihl MS 270c
Stihl MS 461
