Author Topic: Water doesn't appear to be circulating into the house  (Read 6966 times)
Tree_Killer
  • OWF Model: MF5000SS
« on: October 26, 2014, 06:54:24 PM »
I just tried to fire up the mf5000 for the season, but it appears I have a problem.
The wood stove reached temp of 180.  But inside the house the temp readings are only 145 on the one pipe, and 80 on the other.  I checked all the valves multiple times, and everything was open.
First picture shows the circulator that I think is not working properly. The pipe coming into the top is hot, but pipe coming out is cold...the feed to the furnace.  Would I be correct in thinking I should replace it?
Second picture is of the model number.  Should I do a direct replacement with another Taco? Or is there a better choice?
Climb High Tree Service
Lebanon PA
Certified Arborist
"Kiss My Axe"
fireboss
Re: Water doesn't appear to be circulating into the house
« Reply #1 on: October 26, 2014, 06:59:40 PM »
You probaly have an  air bubble can you bleed it?
Tree_Killer
« Reply #2 on: October 26, 2014, 07:07:32 PM »
I guess I can disconnect the bottom flange and check there for air.  I will try that tomorrow
Lebanon PA
Certified Arborist
"Kiss My Axe"
« Reply #3 on: October 26, 2014, 07:39:29 PM »
take a wrench and whack the housing a couple of times, it more than likely is simply seized up and about 90% of the time that will free up the impeller, the motor and impeller can be removed from the housing by removing the 4 7/16th's bolts and that gives you access to the impeller, simply turn it with your hand until it frees up then re install.
Tree_Killer
« Reply #4 on: October 27, 2014, 05:42:59 PM »
The circulator is toast...propeller was messed up and deteriorated.
So replace with the same Taco pump? Or go with another/better brand?
Lebanon PA
Certified Arborist
"Kiss My Axe"
« Reply #5 on: October 27, 2014, 06:39:48 PM »
A Taco 009 will get you a bit more flow
Tree_Killer
« Reply #6 on: October 27, 2014, 06:47:39 PM »
it is a taco 009-f5. Just wasnt sure if it was the best product out there
Lebanon PA
Certified Arborist
"Kiss My Axe"
« Reply #7 on: October 27, 2014, 06:54:25 PM »
Not a bad circ but I would rip out that darn Flo check entirely on the wood boiler loop
