Poll
Corner Plates Gas Burner plate
Corner Plates
- 0 (0%)
Gas Burner
- 0 (0%)
Total Members Voted: 0
Author Topic: Removable corner plates e1450  (Read 7731 times)
jeffsa22
  • OWF Model: E1450
« on: October 27, 2014, 08:04:17 PM »
I removed to clean I may  have mixed up the sides up do side air holes face towards door also the empty hole for gas burner is loose can pull out about 1/4 inch I assuming that should be tight thanks for the help
Jack72
  • OWF Model: E-1450 (11)
Re: Removable corner plates e1450
« Reply #1 on: October 27, 2014, 08:46:38 PM »
Yes toward door  and yes it should be tight
Jack
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
Roger2561
« Reply #2 on: October 28, 2014, 03:46:40 AM »
jeffsa22 - welcome to the forum.  How long have you had your E-classic 1450?  I'm going on my 4th season with my E-Classic 1400.  The 1400 doesn't have the removable corner panels.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
5050racing
  • OWF Brand: CB-1450
« Reply #3 on: October 31, 2014, 06:12:41 PM »
Has anyone use some never seize on the corner plates to aid in removal or do u think it would just burn up I heated them a little to help
« Reply #4 on: October 31, 2014, 11:20:31 PM »
Not sure what never seize is rated at temp wise, I do know it's not near as good as it was. Most likely has been made "environmentally friendly"  which in plain english means it ain't worth a crap anymore.
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
« Reply #5 on: November 01, 2014, 06:38:33 AM »
I do think the make a high heat one its cooper color !
5050racing
« Reply #6 on: November 01, 2014, 03:08:54 PM »
I'm going to try it
5050racing
« Reply #7 on: November 01, 2014, 03:14:43 PM »
The temp on the steel can't be that high on the outside near the 190* water filled jacket in the corners with the air blowing thru!I know it's hot but not like in reaction chamber!maybe 500 if that just thinking out loud?
fireboss
  • OWF Model: 6048
« Reply #8 on: November 01, 2014, 04:22:51 PM »
I have seen it in the auto parts store now that I think about it!
jeffsa22
  • OWF Model: E1450
« Reply #9 on: November 01, 2014, 05:24:09 PM »
Thanks for the answers this is the first heating season with it so far with it roger so good still getting some smoke I used never seize on the metal elbow on the primary fan so it doesn't stick in tube it was the copper stuff that's all I use let u no how that works maybe try in corners does anybody no if it its normal for the secondary air to kick when door is open some times get flames coming out of door is this normal thanks for all of the info
5050racing
« Reply #10 on: November 01, 2014, 05:50:50 PM »
The click and flames same here,I try to look at the firestar when it's been burning on a cycle to heat water and time it when it's in the 3 rd stage burn n not much flame,smoke out the door that's what's nice about the firestar if u have it.
Jack72
« Reply #11 on: November 02, 2014, 04:57:07 AM »
Here's the copper
Nickel grade is in the 2000 range    I would say its worth a try can't hurt
When I had my 1450 the creosote runs into the corner and sits on the top lip of the front corner plates if you get that out first that's most of the resistance/your problem I would always pop mine out when it was pretty hot as soon as creosote cools it's much more difficult.    When I wanted mine out I would take the central boiler issued hoe turn on its side the flat part by the hoe and put under the lip of the corner plate and push down against the plate where the door shuts against.  and use as a leverage bar using your  own weight and she would pop out for me   I started using a hammer at first to get them out and it was to hot to  stick my face in there to see and  get a good swing and all that did was bend the corner plate lip it works but not the best option.
Hope I'm making sense
Good luck
Jack
« Last Edit: November 02, 2014, 05:04:37 AM by Jack72 »
Stihl 046 036 009
5050racing
« Reply #12 on: November 03, 2014, 01:29:06 PM »
Yes sounds good,hot is better
