Author Topic: Fittings kits  (Read 4520 times)
Corngrinder
  • OWF Model: 5036
Fittings kits
« on: October 27, 2014, 10:48:24 PM »
Is it a good idea to use Teflon tape on any/all of the threaded connections for the various fittings kits CB sells?  I have a kit for hooking up the thermostatic valve and a kit for hooking up a plate HX.  Should I use tape on the threads, or not?
Husqvarna - Rancher 460, 18"
28 Ton Splitter
Re: Fittings kits
« Reply #1 on: October 28, 2014, 03:40:25 AM »
The guy who installed my OWB used teflon tape on all threaded fittings.  It will not hurt a thing.  Roger
Re: Fittings kits
« Reply #2 on: October 28, 2014, 06:54:35 AM »
Well yes and no, teflon tape is a lubricant as well, makes it quite possible to over tighten something and crack it. The use of tape and common sense at the same time won't hurt a thing though.
Re: Fittings kits
« Reply #3 on: October 28, 2014, 07:14:23 AM »
Common sense, what's that?   ;)  Roger
Re: Fittings kits
« Reply #4 on: October 28, 2014, 01:21:01 PM »
I actually prefer using pipe dope, when putting threads together!
...but yes, you must use SOME common sence  :bash: when assembling NPT connections
