Author Topic: Wye strainer in supply  (Read 5691 times)
american-pacemaker
  • OWF Brand: P & M
  • OWF Model: OPTIMIZER 250
« on: November 03, 2014, 04:30:49 AM »
Should the wye strainer be installed before the pump or after the pump on the supply line to the flat plate heat exchanger ?
Thanks
Re: Wye strainer in supply
« Reply #1 on: November 03, 2014, 04:34:11 AM »
I like to put them after the circ, I find that after they are installed, nobody ever cleans them and then as they get dirty the circ starves for water and destroys the circ.
american-pacemaker
  • OWF Brand: P & M
« Reply #2 on: November 03, 2014, 04:42:13 AM »
I am going to plumb a bypass around it so I can clean it when the boiler is running. I will install it right next to the exchanger with the pump pumping into it. Does it matter how close the pump is to the heat exchanger ? Thanks Slim.
« Last Edit: November 03, 2014, 04:53:27 AM by american-pacemaker »
« Reply #3 on: November 03, 2014, 06:50:38 AM »
Agree with this a hundred percent, a pump can force water the an less than clean screen, however trying to pull water thru it is another story.
« Reply #4 on: November 03, 2014, 07:58:44 AM »
...as long as you are on the supply side of the FPHE you are good.
But I do agree, easier to push thru and pull thru with pump  :thumbup: :thumbup:
