Author Topic: insulating copper pipe  (Read 5733 times)
Pinehouse4
  • OWF Model: BL 34/44
« on: November 03, 2014, 10:26:49 AM »
Hi guys,
I want to know what options there are for insulation copper pipe. For my install it was necessary after the Logstor entered the house to run 100 feet of 1 1/4 "copper within the basement along the floor perimeter ( 50 feet each way.) Corning SSL fiberglass is $4.44 per foot. I know I can use Roxul but I was hoping there was a slip on foam tube that could take the heat.
By the way, does anyone know if there is a foam sleeve that can take boiler temps?
There is too much heat and it is uncontrollable without it being insulated. I have cast iron rads there for that purpose but they are turned off of course.
Thank you,
Bob
Stihl 028
Stihl 046
Wallenstien 820 wood processor
JD 6300 4 WD loader, blade, blower, forks,
BL 34/44 working great.
Re: insulating copper pipe
« Reply #1 on: November 03, 2014, 03:48:22 PM »
I have foam pipe insulation on mine, may still have some left.
BoilerHouse
  • OWF Brand: Home Built
« Reply #2 on: November 03, 2014, 06:21:07 PM »
Ditto....foam sleeves from the hardware store.  They take boiler water temps + no problem.
Muskoka, Ont
DaveWertz
  • OWF Model: H4
« Reply #3 on: November 03, 2014, 07:18:40 PM »
Same here. Its cheap and easy to do. I went a little overboard with mine though. I wrapped ALL my copper pipe in the slip on foam.
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
hoardac
  • OWF Brand: Heatmaster G-200
« Reply #4 on: November 04, 2014, 09:53:41 AM »
I put mine in black foam tubes then covered it in foil-bubble-foil and metal tape works really well and looks pretty good to.
Pinehouse4
« Reply #5 on: November 05, 2014, 09:34:45 PM »
Thanks guys for your import.
Here all I can find in a foam type is specifically rated for 180 F maximum. It is available at HD in 1 1/4. However I chased down the manufacturer in Toronto and they have a rubber based polyethelyn foam in 1 1/4 inch in 6 foot sticks with a pullt tab self sealing joint, it actually provides a 1 3/8th inch diameter.
I have a box ( 144 feet ) ordered which should arrive tomorrow. I will report once I receive it.
After finally having the boiler and therefore removing any fire risk from the three wood stoves I used before I cannot risk covering this boiler feed water with  anything that is not rated that high. I recall Logstor reporting 1 degree of heat loss per 100 feet of pipe, I am about 135 feet away.
The price of this was quite reasonable, I will report soon as I said and intend to install this weekend. Hopefully it may assist others. I can also use it on the boiler piping.
Bob
Stihl 028
Stihl 046
