Author Topic: Need Help - New Owner  (Read 14610 times)
Maxnchej
  • OWF Brand: Portage and main
  • OWF Model: Bl2840
« on: November 10, 2014, 07:14:15 PM »
Hi All,
I just bought a new bl2840. I helped install it with the dealer who I purchased it from and had it up and running on Saturday Nov 8. The install went well and I will post some pictures once I get them off my phone. I'm located in Southern Ontario and it hasn't been that cold so far but the boiler is running heating my water and house, house is at 71, very nice  ;D. House size is 2400 sq feet plus 1400 in a unfinished basement. So my BL has been running for just over 48 hours and I have a number of questions.
1. I have black water/creosote coming out of the clean out door. I called PM today and they indicated that this is due to it being not to cold outside. My question is are others having this issue? If so do you only run the stove when it is really cold? Here in Southern Ontario it can have large temperature swings within days from very cold to mild.
2. When I talked to PM they told me to do a high temperature firing, so I did one tonight. Brought the stove up to 195 and then closed the door. It raised to 197 and then water started to come out of the cap, and since cooled back down into the 180 range. It also made a knocking sounds when I had the ash door open with no fan running to do the high firing. Is this normal? Should the water come out?
3. I also noticed a large build up of creosote on both the fire camber and ash doors and in the fire camber as well. I scraped them down but was surprised to see that much. I'm burning two year season wood. How often should I be cleaning and should I be seeing a big build up so soon?
4. I have my temp set to 180 and a diff of 10, does that sound good?
5. Every time I open the door I get a face full of smoke. I have tried opening it a crack and waiting a few then opening but still smoke. I end up smelling like smoke and I was hoping that it would be more like a wood stove. Do others have this issue?
Hoping someone can help me since I'm concerned that I'm doing something wrong. It was a large investment and don't want to mess it up.
Re: Need Help - New Owner
« Reply #1 on: November 10, 2014, 07:20:54 PM »
Who in the heck is telling you this stuff, I'm sending you my contact info, Please call me tomorrow evening
Maxnchej
  • OWF Model: Bl2840
« Reply #2 on: November 10, 2014, 07:35:55 PM »
It would be great if I could talk to someone, I'm struggling and want to make sure that I'm doing everything right. I have been using a wood stove for 10 years and never had a issue. I look forward to hearing from you slimjim.
« Reply #3 on: November 10, 2014, 07:39:16 PM »
I sent you my contact info including E-Mail, Please send me yours as well !
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
« Reply #4 on: November 10, 2014, 07:44:05 PM »
You're doing ok. It's a learning process. As long as its burning wood and making heat, you'll figure it out. They make creosote and smoke. That comes with the territory.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
oaky
  • OWF Model: BL-2840
« Reply #5 on: November 10, 2014, 08:09:53 PM »
Maxnchej, I'm a new owner of the BL-2840, I've been running mine going on five weeks now, so I may be able to answer some of your questions.
1-When I started my BL-2840 for the first time, I had some water coming out of the ash door, it cleared up after a few cycles. It may help to set your boiler temperature to 185-190F degrees for the day, as the temperature goes up, you will have some water expansion which will overflow through the water gauge opening. Another thing I learned, is to be certain the ash door is shut very tightly.
2-Whenever I open the ash door fully, I hear a pulsating sound or vibration which makes my draft blower's air back draft flap rattle, I would imagine this is normal.
3-Once the outdoor temps get colder, the creosote will be minimized.
4-180 with a diff 0f 10 is o good setting. I've been running mine at 185 diff 10 just to keep the glassy creosote under control until colder temps set in which should begin tomorrow, 20's for the highs & single digits for the overnight lows for the next eight day forecast for Wisconsin.
4-I get a lot of smoke coming out the loading door too as I'm loading it. I just bring whatever amount of firewood I need for loading, next to the stove & toss it all in before the wood begins to smolder.
Hope this helps you some. :)
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
Uponthehill
  • OWF Model: 250 & 461 Stihl
« Reply #6 on: November 10, 2014, 08:39:46 PM »
Maxnchej,
I am also a new 2840 owner.  Fired mine for the first time the same day you did, November 8, 2014.  Very please with how quickly the fire took and how little smoke it produces.  Started with a small torch, shut the door and within minutes, FIRE.  I also get smoke out of the door.  Depending on the wind and the time I load, the smoke does vary from heavy to very little.  Like oaky said, load quickly to minimize smoldering smoke...  Be cautious.  If you load just after the blower shuts off, read the caution sticker on the door.   It will re-ignite and FLASH.  I have mine set at 190 +/- 10.  I like to run mine hot.  Just under steam temperature of 200-205 degrees.  It has not gotten above 194.  Let it do what it gets paid to do...  I made the same mistake you did.  I filled the water jacket to full when it was cold.  The stove got hot, water expanded, and it had to go somewhere.  I've made a mental note to myself to check water level only when hot.  After it reached 190F, the guage leveled out just below the full mark.  I also think I am going to buy another section of stove pipe to get it up a little higher.  Mine sets just beside my shop and I think if the exhaust was up a little higher, it may pull a draft through the front door and reduce / eliminate smokin' out the front.  Does either of you have a pipe cap on your stove pipe?  I'm not sure if we should even worry about having one on the pipe.  Just asking...  It's not cold here yet, but I believe I'll be getting what oaky mentioned tomorrow or Wednesday.  Looking forward to some cold days in Kentucky (never thought I would be saying that...)
Send me your contact info and I can share some pics of my install.  I've not yet figured out how to attach even the smallest file.  It tells me the file is too large and to contact an administrator.
MerrellRoofing
  • OWF Brand: P&M
« Reply #7 on: November 10, 2014, 10:27:37 PM »
I have 3 sections of pipe. I can tell you, mine still smokes out the door when I open it.
Mid-Michigan
Chevy Dually Dumpx2
sceptre74
  • OWF Model: BL 28-40
« Reply #8 on: November 11, 2014, 03:44:11 AM »
I get condensation out the ash door especially if I'm burning wood that I don't have under my lean too. We have been getting lots of rain as of late. I hope it clears up when the colder weather arrives
Maxnchej
  • OWF Model: Bl2840
« Reply #9 on: November 11, 2014, 04:25:08 AM »
Maxnchej,
Thanks for responding to my treed, funny that we both started up on the same day, I'm also looking for cold weather, based on the news should be getting cold here tomorrow and I'm looking forward to it.  :thumbup: When I called PM yesterday they told me not to put a cap on it since it will create condensation and the water will go back into the stove. I asked them what about rain and they said it shouldn't rain during the winter. I informed the rep that it rains in southern Ontario and they said I would be OK without one.
I still need to put in my treatment, my dealer wanted me to wait a few days before I added it, when I talked to PM they informed me to put it in right away, but since I had the issue with the water coming out of the top I decided to wait until tonight.
Are you having a large build up of  creosote in your stove?
Have you sent in your sample yet?
Maxnchej
  • OWF Model: Bl2840
« Reply #10 on: November 11, 2014, 04:29:12 AM »
You make a good point, all of my wood does sit outside uncovered since I just have to much to cover and it has rained a lot. I wouldn't think surface water would cause that big of an issue, I have been burning the same wood in my wood stove for 10 years without issue and never had a build up in my chimney, but I guess it could be one reason why.
I just loaded my stove this morning and after my hot burn last night and scraping I haven't had a more leaking out of the ash pan. Will be interesting to see what I come home to tonight.
Thanks for replying .
Crow
  • Eastern Ontario
« Reply #11 on: November 11, 2014, 04:41:25 AM »
 I find the best way to avoid the smoke is to load when the fan is running, not recommended but I never had issues - yet. When fan is running there is little to no smoke, I  can see without the flashlight in hand while stirring coals and have never had a flashback while loading this way.
« Reply #12 on: November 11, 2014, 04:48:37 AM »
Two different boilers, The extra passes and heat trap are designed to make the unit more efficient, the stack temps on your B-L will be far lower than your old stove, the trade off for that efficiency will be that your fuel must be in a bit better shape, rain soaks into the wood when uncovered, can you still burn it? well yes you can in a campfire or straight up conventional stove but you will burn far more more, also do not stuff the firebox full of wood, only put in enough to get through until you return, shoot for 12 hours.
oaky
« Reply #13 on: November 11, 2014, 06:50:44 AM »
I have a chimney cap on mine, P&M says not to. It does rain here in Wisconsin during the winter whenever we get a mild spell and precept in the forecast. Cleaned out my 5' of chimney after five weeks of operation & got a handful of fine dust. You may want to put in the treatment soon as possible, depending on your water quality, the water-jacket could start to rust & you will need to flush out the water-jacket & water lines if it gets too bad.
Husqvarna 272
Husqvarna 55
Maxnchej
  • OWF Model: Bl2840
« Reply #14 on: November 11, 2014, 04:56:16 PM »
I put the treatment in tonight, I would have when I was filling it but the dealer informed me not to, Wish I would have done it anyway. Where I live it also rains during the winter, just wondering if I should get a cap for mine. Did you buy the cap from PM or get somewhere else?
