Author Topic: Ash  (Read 6277 times)
Maxnchej
  • OWF Brand: Portage and main
  • OWF Model: Bl2840
Ash
« on: November 16, 2014, 10:01:56 AM »
Clean out my bl2840 after the first week of burning and I was shocked by how little ash there was for the clean out. I used the scope and pushed it in along each side and the middle multiple times and only got about 2/3 of a ask pail full. When I was using my wood stove I would get the same pail full in less then a week and would not be burning 24x7, really shows how well these units work!
When I did my ash clean out I was cleaned out he heat exchanger, was very little of anything up there and tried to scape down the walls in the firebox. I found the scraping hard since the top is round and the unit is very deep. Are others doing this?
I'm currently running my unit at 189 with a diff of 10 and don't seem to have much build up.
Are others doing anything else for weekly maintenance?
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
Re: Ash
« Reply #1 on: November 16, 2014, 10:09:29 AM »
Someone's ash pan warped from the heat. I leave mine out and push it in to scoop the ashes. Is everyone else leaving there's in?  I'm gonna put my scraper on the grinder to round it off a little. I've left the fire pit alone and just let the ashes fall thru as they wish.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
oaky
  • OWF Model: BL-2840
Re: Ash
« Reply #2 on: November 16, 2014, 11:06:32 AM »
P&M says it's best to leave out the ash pan because of the firebrick grates getting very hot. I have a thin layer of that glassy creosote in the fire box walls, haven't done any scraping, figure when the heat gets hot enough, it'll burn it off. P&M suggest to do a hot burn once or twice a week to control the creosote build-up. I'm getting on average, a full ash pan every week, nothing much in the secondary heat chamber.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
Maxnchej
  • OWF Model: Bl2840
Re: Ash
« Reply #3 on: November 18, 2014, 04:33:52 AM »
Sorry for the confusion, I don't leave the ash pan in, I just used it to clean out the ash on Saturday. I leave the pan under the stove.
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: Ash
« Reply #4 on: November 18, 2014, 07:41:30 PM »
I put the ash pan under the door and use the cleanout tool to pull the ashes out so I don't push ashes into the air passage from the blower.
