Author Topic: Fire won't re-kindle very well  (Read 8840 times)
danicol12
« on: November 18, 2014, 01:03:15 PM »
I have a 5036 CB stove that has worked perfectly for the past 2 years.  This year when I started it up about 5 weeks ago, it burned hot enough to remove all the leftover creosote from the previous season and performed greatly until now.  Now, it doesn't seem to be getting enough air because the fire won't re-kindle itself very well without some help.  If I open the door and stir up the logs already in there, it will take off, but it doesn't seem to take off on it's own.  I checked to make sure the draft door was open and it is open every time.  The draft door seems to be open all the way.  Could there be something in the stack plugged up tight enough to not allow enough air flow or something?  I do not have a blower on this boiler, but it's worked just fine for the past couple years.  Any ideas?
Big Wood
Re: Fire won't re-kindle very well
« Reply #1 on: November 18, 2014, 02:45:36 PM »
Depends on the kind of stack steel box type there is a cover to slide up might need a hammer if you have not had it open if it is the stainless tee take the cover off and check it out but be careful if you still have a fire going it might draft on you
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #2 on: November 19, 2014, 06:04:18 AM »
Are you burning the same wood type?  Same moisture content?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
dwneast77
    • HeatherWood Gardens
« Reply #3 on: November 20, 2014, 07:37:46 AM »
Being that it's a non-gasser,  I've seen other posts in the past about the chimney getting plugged.  Might be worth a check if you have not already.
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
walkerdogman85
  • OWF Model: H-4
« Reply #4 on: November 25, 2014, 08:15:19 PM »
I have had the same issue with my hardy, it has a blower and won't fire real hard. It's because I didn't cut any wood for over a year and I am forced to burn fresh green oak cut about two months ago. I know moisture has a lot to do with it regardless of what anyone tells you! Seasoned wood is where it's at!!
Michael West
Central Ohio
fireboss
« Reply #5 on: November 25, 2014, 08:48:34 PM »
Leave the door open and give your self a good cleaning out! If your wood is green you may want to install the fan its very easy !
walkerdogman85
  • OWF Model: H-4
« Reply #6 on: November 26, 2014, 07:00:00 AM »
I usually save up cardboard and let it clean its self out weekly. I did manage to get the fire going really good last night by leaving the door open for a while..
Michael West
Central Ohio
Pit Crew
  • OWF Brand: Centeral Boiler
« Reply #7 on: November 29, 2014, 01:55:08 AM »
It`s been over 10 days, he must have got the fire going :thumbup:
North east Ohio
Since 1960
patton acres
  • OWF Model: 5036
    • Garden Tractor Salvage Yard
« Reply #8 on: December 02, 2014, 06:35:25 PM »
I have a 5036 and added a fan this year. WOW!!!!!! what a difference. I wish I had it since 09 when I put the boiler in.
MTJAG
  • OWF Model: CL5036
« Reply #9 on: December 06, 2014, 05:15:21 PM »
where did you get your fan and where do you install it?
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
« Reply #10 on: December 06, 2014, 06:21:52 PM »
The fan mounts on the door.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
