Author Topic: Grounding OWB?  (Read 12594 times)
AirForcePOL
  • OWF Model: G400
Grounding OWB?
« on: November 19, 2014, 09:04:07 AM »
Has anyone ever heard that a owb should be grounded?  Someone a friend of mine was talking to said that it should be grounded at the boiler to get rid of electrical current caused by the water flowing through the pipes?  Sounds weird to be but I just figured I would ask.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
Re: Grounding OWB?
« Reply #1 on: November 19, 2014, 10:59:18 AM »
Portage and Main says in the manual to ground the boiler.
installed in 2014
jerkash
  • OWF Brand: Legend
Re: Grounding OWB?
« Reply #2 on: November 19, 2014, 11:17:05 AM »
I grounded mine
oaky
  • OWF Model: BL-2840
Re: Grounding OWB?
« Reply #3 on: November 19, 2014, 01:46:49 PM »
I would assume the owb is grounded from the ground wire in the electrical wiring to the owb, correct?
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
jerkash
  • OWF Brand: Legend
Re: Grounding OWB?
« Reply #4 on: November 19, 2014, 04:18:11 PM »
Just ground the main part of the OWF to the ground.  You don't need to tie into the electrical ground as it should be grounded to the OWF.  I just unscrewed a 3/4" nut on mine and wrapped a ground wire around that and and retightened the nut and hooked the other end to a ground rod.
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: Grounding OWB?
« Reply #5 on: November 19, 2014, 09:22:12 PM »
If the Electrical is connected to the steel structure, it should be grounded.
Also, chances are, the heating system in the house is grounded all over the place.
But if the owner's manual says to ground it, it can't hurt anything.
Woodboiler
  • OWF Brand: Wood Doctor
  • OWF Model: WD8000
Re: Grounding OWB?
« Reply #6 on: November 22, 2014, 04:38:25 PM »
I used to be a Wood Doctor Dealer and Installer.  I would always install copper ground rod next to the  stove and ground the stove with #6 stranded copper to the ground rod.  On Wood Doctor models, there was a electrical lug on the leg of the stove. There is a theory out there that moving water in the stove and pex creates a slight electrical current.
Ed
Michigan Wood Boiler repair
Parts and Service
AirForcePOL
  • OWF Model: G400
Re: Grounding OWB?
« Reply #7 on: November 22, 2014, 04:41:37 PM »
That's what he was talking about.  Do you think it's necessary?  I guess it wouldn't hurt... but yes, I would assume that if the power is grounded to the stove it would already be grounded....
Athens, Illinois
Stihl MS 290
crankshaftdan II
  • OWF Brand: Heatmor
  • OWF Model: 400CSS
Re: Grounding OWB?
« Reply #8 on: November 22, 2014, 06:42:18 PM »
Seems that I read in a owner's manual that you need two (2) ground wires spaced 10' apart.  As most OWB's are setting out in the open and even if they are grounded back to the electrical wiring-what's to say that during  electrical storm the guy above singles out your flue pipe for a direct hit-I would rather have the juice go into the ground rod first as it's supposed to take the path of least resistance???  If you get a direct hit-probably ALL electrical will be fried???  Anyone had a direct hit????  Please chime in-I'm just a bystander at this time. :pic:
dwneast77
    • HeatherWood Gardens
Re: Grounding OWB?
« Reply #9 on: November 22, 2014, 07:59:10 PM »
I know when I installed my CB I was told it was required and my dealer included the ground rod with my other accessories.   When I installed my Wood Doctor I saw the ground lug as mentioned above and so I went ahead and sunk another ground rod for that furnace too.  Figured it was required by all brands.  As someone else mentioned, I remember hearing about the electrical charge produced by the moving water.  Haven't I seen some guys post out here in past years about anode rods also, like in an electric water heaters??  Maybe I'm mistaken.  Not sure.   ???
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
Re: Grounding OWB?
« Reply #10 on: November 22, 2014, 08:19:00 PM »
If your worried about lightening, a piece of 6 gauge ain't gonna cut it. Still have lightning rods on the farm house, the grounding cable are woven copper wire big around as my ring finger.
Two grounding rods is not a bad ideal though. I have a fence charger that requires three grounding rods 10' apart. Then I have a ground wire running around the pasture with another three grounding rods various places on the perimeter of the pasture. Charger puts out 16000+ volts with a capacity upwards of 21 joules. A lightning bolt is how many million volts and what amperage?
whitepine2
  • OWF Brand: P&M 250
  • OWF Model: 250 optermizer
Re: Grounding OWB?
« Reply #11 on: November 27, 2014, 05:30:35 PM »
  MY first boiler forgot to ground within 5 years was rusted through.New P&M put in 6 foot rod all the way in and grounded,three years now and not a sign of rust. Don't know if that is what caused first to rust but live and learn what's it cost to do it right less than $20 it cant heart
anything so why not and be safer for it.
