Author Topic: fire creep... help!  (Read 4682 times)
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
fire creep... help!
« on: November 19, 2014, 04:45:14 PM »
Fire creep …I have my boiler set for 170 /10 …trouble is the "heat creeps up " after shut down, and makes my boiler blow off ! ( always at 4 am in the morning when I fine it btw), LAST nite> outside temp at 5 pm was 27 degs and my "zones" had just finished called for heat and were closing. Weather was a wind of 9 ta 16 mph Boiler water, after all day was 140 with only a oilcan size of wood/coal left = GOOD! I load 1, 6" log and 3, 2" and a 4" dry azz spruce and a couple 2by construction stud cut off’s of 2by6/8 . I close the door a turn on the blower and the fire gets a ripping and 20 min latter I’m at 170 deg /boom off goes the AQ-s . then the creep starts/ slow …the stove and fire brick in this 1200lb monster holds the heat well …..all the lines are insulated and I get NO temp change in the 120’ 1 ¼ of line in the loop GF alpha is running 6 gpm with the no call for heat. So last nite, while we were a sleep, the wind stopped and the outside temp went to a toasty 37 . So am I’m building a fire to big?? I’m at a ¼ load…AQ--s is good ….there is no leaks of air etc…the heat from the 20 min run ….just crept up till boom…(210) and it only happens < once a week thus far. My thinking to fix this is to place a AQ-s on the supplyline coming out the top of said boiler "set on" something like 200 with a diff of 15 or 20 ,which would turn on/open a zone valve and dump the spare 15 of heat into a unini heater /something till it hits <185 deg then close OR how’s about setting my AQ-s @t 150 / 5 leaving room for 50+degs of creep < cheap 2 !!
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: fire creep... help!
« Reply #1 on: November 19, 2014, 09:16:56 PM »
Sounds like an air leak, but looks like that's already ruled out. It should virtually quit making heat when it shuts down. Even if your house wasn't using much it would likely lose enough, just through insulation on your system, to keep it in check. Sure sounds like an air leak.
« Reply #2 on: November 20, 2014, 04:00:55 AM »
By any chance are your circs tied to the blower circuit? If so, run the circs constant.
atvalaska
  • 907, no vacancy !
« Reply #3 on: November 20, 2014, 02:48:26 PM »
aq stat  turns on blowers at 160 ...off at 170,      cic pump runs 24/7   last nite I went 155/10   ... no air leaks I sealed up a few small holes in one of the 2  a fan motors /wiring area  > after I did that the dam fire went out one time ..cause of "near no air" so I peeled off a bit of what I coverd and its better....this thing is lined on each side of the grate  wit 3"fire brick   for use with coal....I think maybe a rip roaring fire bleeds the brick..... thru to the "wall"  after the blowers come down ....??? i''m going nutz.
