Author Topic: Chimney length effect on natural draft  (Read 9309 times)
jamesbodeis
  • OWF Model: 7500
« on: November 19, 2014, 05:32:46 PM »
Was a little bored out deer hunting tonight and started wondering what effect chimney length has on a natural draft stove.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
BoilerHouse
  • OWF Brand: Home Built
Re: Chimney length effect on natural draft
« Reply #1 on: November 19, 2014, 06:01:52 PM »
Definitely an effect.  Higher stack equals greater draft.
Muskoka, Ont
Pinehouse4
  • OWF Model: BL 34/44
« Reply #2 on: November 19, 2014, 06:20:33 PM »
I agree, that has been my experience using wood stoves for 35 years provided of course the diameter matches the stove.
Meaning you wood not put a 6 inch pipe from a stove into a 12 x 12 flue, you may think it better but it is not.
Bob
Stihl 028
Stihl 046
Wallenstien 820 wood processor
JD 6300 4 WD loader, blade, blower, forks,
BL 34/44 working great.
jamesbodeis
  • OWF Model: 7500
« Reply #3 on: November 19, 2014, 06:23:19 PM »
Is there then a point of diminishing returns? Too much draft?
Ridgewood 7500
Jonsered 2260
BoilerHouse
« Reply #4 on: November 19, 2014, 06:46:14 PM »
Too much draft could be a bad thing. First the expense and bother of installing and maintaining extra lengths of chimney pipe.  Then, I would think that either you would run with the damper partly closed, or the fire would burn hard and fast and carry a lot of heat up the stack.
Muskoka, Ont
Pinehouse4
« Reply #5 on: November 19, 2014, 06:55:18 PM »
If it were an air tight stove then in theory you regulate the air that can be sucked up the chimney. It will ideally suck up whatever you choose to give it.
I see no point in adding length beyond what is needed ( although my wife may disagree )  :-[
Bob
Stihl 028
Stihl 046
jamesbodeis
  • OWF Model: 7500
« Reply #6 on: November 19, 2014, 06:57:35 PM »
All makes sense. I just wondered if additional stack would help the fire get going quicker. I put three feet on a bit ago and it seemed like the recovery time improved. I've noticed during the drive hunting a lot of stoves with tall chimneys and it got me thinking.
Ridgewood 7500
Jonsered 2260
« Reply #7 on: November 19, 2014, 07:36:59 PM »
Not quite sure why a high stack is a bad thing.. As said on here.. A higher stack with a air draft boiler means a quicker ignition of the fire instead of smoking.. Quicker recovery time .. Dampers and all that is bs your not gonna draw air unless you got a air leak somewhere.. I'm 19ft up with forced air draft.. No affect on my end... If you thinking of going higher go for it.. So much better
« Reply #8 on: November 20, 2014, 04:18:36 AM »
And watch your stack temps as well as wood consumption rise!
jamesbodeis
  • OWF Model: 7500
« Reply #9 on: November 20, 2014, 09:02:44 AM »
I can see where wood consumption could increase and understand that part. Being new to all this I don't know the importance of stack temps. Could you explain it to me?
Ridgewood 7500
Jonsered 2260
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #10 on: November 20, 2014, 09:18:32 AM »
Higher stack temps just means the heat is not being absorbed through to your water jacket, higher stack temp equal more wasted heat think of it like a forced air furnace 80% efficient you must have class b venting due to the high vent temps 96% efficient you use PVC and the vents only get luke warm hope that helps
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
jamesbodeis
  • OWF Model: 7500
« Reply #11 on: November 20, 2014, 11:43:15 AM »
I see what your saying. Thanks.
Ridgewood 7500
Jonsered 2260
« Reply #12 on: November 20, 2014, 03:04:13 PM »
There is no extreme like a wow.. Buddy of mine has the same boiler as me with no stack.. Pretty much burn the same.. We both have 1800sq foot homes
« Reply #13 on: November 20, 2014, 03:17:40 PM »
Have you ever actually measured your stack temp?
« Reply #14 on: November 20, 2014, 03:57:37 PM »
No I haven't
