Author Topic: Removing Logstor foam from the pex lines  (Read 6441 times)
gainerspot
  • OWF Brand: P&M
  • OWF Model: Ultimizer BL 2840 (soon)
« on: November 20, 2014, 03:24:54 PM »
Is there some kind of secret of how to remove the foam from the logstor pex lines? :bash:
ran3465
Re: Removing Logstor foam from the pex lines
« Reply #1 on: November 20, 2014, 03:56:40 PM »
Time, big flat screwdriver, and a utility knife. I was able to separate the two lines with the screw driver, and used both hands and kinda twisted on the foam really hard and got most of it off. Then Used utility knife to "shave" the residue off.
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
« Reply #2 on: November 20, 2014, 07:38:08 PM »
I used an old kitchen knife. Probably a 10 inch. I keep a few in my tool box. It came in handy for once.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
gainerspot
  • OWF Brand: P&M
« Reply #3 on: November 20, 2014, 08:10:48 PM »
Used my 10 inch butcher knife and the old indian burn technique  for the foam. The dremel tool to keep from cut outside wrap and not go to deep.
Thanks for the help. Should fire up my BL in tomorrow or Saturday.
Pinehouse4
  • OWF Model: BL 34/44
« Reply #4 on: November 21, 2014, 10:52:01 AM »
I broke a jig saw blade in half and then cut down the black covering using the white lettering line as a guide, cut the bottom with a knife.
Then used a drywall saw ( keyhole saw ) and cut down between the two pex pipes, holding on to one.
Then grab one foam covered pex and twist hard, it will loosen from the pex and it will slide off easily, usually in 10 to 16 inch pieces.
Bob
Stihl 028
Stihl 046
BL 34/44 working great.
