Pages: 1 [2]
Author Topic: Churgling in my Taco 007 circulator  (Read 15823 times)
oaky
  • OWF Model: BL-2840
Re: Churgling in my Taco 007 circulator
« Reply #15 on: November 28, 2014, 06:48:17 AM »
Are you seeing any visible steam from the vent tube?
I'm not sure if you mean while the circulator is making that sound or in general? In general, I believe there is a very small amount of water vapor, which I understand is normal. Otherwise, I never really paid attention or noticed excess steam  while the circulator is making this sound.
2840 has been staying within 3 degrees of set temp & no unusual sound from the circulator the last couple of days, winds have been fairly calm. Today, I believe they are suppose to pick up again, so I'm prepared to turn boiler set point down from 190 to 180 & throw in a light load of large pieces of firewood, seems to be the only answer.
Husqvarna 272
Husqvarna 55
27 Ton Cub Cadet Log Splitter
« Reply #16 on: November 28, 2014, 08:10:11 AM »
Unless you have an extended stack on the B-L, the wind should not effect it overheating.
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #17 on: November 28, 2014, 04:06:41 PM »
mine does it when it get up near boiling.i don`t worry about it.just keep her closed up temp go down
all is good
austin qc
bluegrass rules
proud appalachian
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
« Reply #18 on: November 28, 2014, 04:16:25 PM »
 I haven't noticed any noises from the pump. I do not have an extended stack either. The power went out on Tuesday when we had high winds so I shut the blower and pump off in case a power surge happened and caused damage to them. Anyways, the power was off for 5 hours and when it came back on I turned the furnace back on and to my surprise the water temp was at my set temp. The BL does use more wood when it is windy.
Pages: 1 [2]
