Author Topic: heatmeater 5000 fan speed  (Read 8872 times)
caper
  • OWF Brand: heatmaster 5000
« on: November 28, 2014, 05:00:25 PM »
just wondering, ive never played around with the fan speed on the back of the furnace, mine is set around 50\%, is there much of a difference if it is lowered, would I get a little longer burn time....today i was at a friends house and his was set at 15% and I was a little shocked and got me thinking...
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
Re: heatmeater 5000 fan speed
« Reply #1 on: November 28, 2014, 09:02:59 PM »
 100% or you take a chance of replacing a fan.
Lineman
  • OWF Model: MF5000
« Reply #2 on: November 29, 2014, 03:44:19 AM »
Good question constable mines at 50% also was wondering same thing. Gonna jack mine up to 100% and see how it runs there. thanks for your input yorder
caper
« Reply #3 on: November 29, 2014, 04:41:20 AM »
thanks for the reply Yoder, so what will the outcome be if i put it at 100%, more air, will the wood burn faster,ive never had an issue with the blower before,is there any benefits to adjusting the lever to 100%, just curious and thanks again...
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
« Reply #4 on: November 29, 2014, 02:02:50 PM »
Wait,  are you talking about fan speed or the damper setting. Damper settings can be adjusted depending on what works best for you. But on the models that had the dimmer switch to control fan speed they should always be left on 100%.
 If you are talking about the adjustable dampers in the back I normally recommend starting a E or C model on 100% and the standard MF models on 50%.
caper
« Reply #5 on: November 29, 2014, 02:12:38 PM »
thanks again Yoder, and yes im talking about the damper setting,sorry for the mix up,ill have to check on the model, cant remember right now and im at work, its a 2008 model,however i bought it in 2012, its at 50 % right now,bye the way,whats the benefits of having it at 100%, this is one part of the furnace that i have never played around with... thanks again...
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
« Reply #6 on: December 01, 2014, 12:29:56 AM »
It just adjusts the amount of air that flows into the fire. On the more efficient models there is the extra bypasses to capture the heat produced if you burn the fire hotter by giving it more air.
AirForcePOL
  • OWF Model: G400
« Reply #7 on: December 04, 2014, 07:49:54 AM »
I had my 5000e on 100% since October.  I was playing around with the damper last night and I moved it back to 70%.  The fire seems to burn much hotter than it did on 100.  I think it was pushing in too much air.  I'm going to leave it on 70% for a few days and see if it makes a difference.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
caper
« Reply #8 on: December 05, 2014, 07:06:05 AM »
thanks for the update bro,keep us posted, mine is still at 50% for now,
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
