Author Topic: water coming from front door  (Read 6547 times)
caper
  • OWF Brand: heatmaster 5000
« on: December 03, 2014, 01:08:09 PM »
Hello guys, im asking a question for a friend, he has a heatmaster 10,000, heating two homes,its brand new, he has to keep a tray in front of the door as it is leaking water daily, he states his wood is not green, he is not loosing any water from the furnace and his damper is set at 75%, does anyone else have this issue,and does anyone know what is going on here and how it can be stopped or fixed, thanks guys, other then this his system is working great he states....thanks for the help guys
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
free heat
  • OWF Brand: ridgewood
  • OWF Model: 6000
Re: water coming from front door
« Reply #1 on: December 03, 2014, 01:41:36 PM »
Could be a few things, it's not all that uncommon. 1)Wood isn't seasoned enough 2) the stove is on idle to much usually happens in fall or early spring. 3) boiler set temp is too low. I would shorten up the burn cycle to no more than a 10 degree swing, turn boiler up to 180 degrees and get some dry wood in there. And then all of his problems should go away!
Ridgewood 6000
Stihl 039, 290
Fiskars x27
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #2 on: December 04, 2014, 05:41:12 AM »
Not to be a fuddy dud, but there are already 2 threads going about this same thing.  It's condensation.  If he has the "E" model, have him open his damper to 100%.  The ash pan door is the coldest spot in the stove.  Any moisture in the wood will cause condensation to form at that door.  It's normal for these stoves and many others.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
caper
« Reply #3 on: December 04, 2014, 09:27:49 AM »
thanks John, ill tell him, and yes I seen the other threads after I posted...ill try better next time....lolol
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
« Reply #4 on: December 04, 2014, 11:07:54 PM »
A door seal leaking air into the firebox can cause dripping. The draft makes a cold spot that causes excessive condensation.
CountryBoyJohn
« Reply #5 on: December 05, 2014, 05:22:41 AM »
Yes, a draft can cause EXCESSIVE condensation.  My stove, as have many others, dripped from day one.  I don't have any air leaks.  Our ash pan doors stick out from the main furnace over 4".  There is no way to get that portion of the door hot enough to prevent condensation.  There is always going to be some.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
