Pages: 1 [2]
Author Topic: Did adding a OWB increase or decrease your power bill?  (Read 21798 times)
Ed165
  • OWF Brand: Shaver
  • OWF Model: 165
Re: Did adding a OWB increase or decrease your power bill?
« Reply #15 on: December 05, 2014, 05:59:00 PM »
All electric house 2500 sq ft. before OWB winter electric was 850.00 to 1000.00 per month after OWB 125.00 per month
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
« Reply #16 on: December 05, 2014, 07:48:11 PM »
Up $20 since I have to run the pump and blower on the stove.
Are you heating water with the boiler?
aries9245
  • OWF Model: Cl6048
« Reply #17 on: December 06, 2014, 07:21:36 AM »
I went up I guess between radiant pumps and owb pump and fan it's alot higher especially in colder months.. Better than paying 7k a yr in propane I spend about 1200 on propane a yr now runs dryer stove top hot water heater and backup for boiler
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
Ridge
« Reply #18 on: December 07, 2014, 07:02:52 AM »
Just got second month bill, saved $30 the first month and second month saved $11 from previous average, still better than average
kc
  • OWF Brand: Earth
  • OWF Model: Mountain Man 505
« Reply #19 on: December 07, 2014, 11:47:04 AM »
Decreased.   The difference in my electric bill is my hot water heater is off.   This is my third winter with the stove and my electric bill drops $40 - $50 per month not running the water heater but the big savings is not having to purchase propane.   With the cold winter last year I figure I saved $3000 to $4000 on propane costs.   Running the pump and small blower on the stove does not burn much juice compared to lighting up a heating element...
kc
Earth Mountain Man 505
Stihl MS361 - 25"
Stihl MS280 - 20"
Stihl 028 Wood Boss - 18"
Sthil MS170 - 16"
Echo CS-305 - 14"
GCTerpfan
  • OWF Model: Classic
« Reply #20 on: December 10, 2014, 02:03:14 PM »
My bill went from averaging $150-$165 to the last being $89.  I contribute it to turning my DHW tank off. A house with 5 kids (two teenagers) and a wife uses a LOT of hot water.
Garrett County, MD
« Reply #21 on: December 10, 2014, 11:03:18 PM »
To be perfectly honest, with two cattle waterers with 750 watt heaters in each, then with two tractors plugged in almost all winter one with a 1000 watt  block heater and the other with a 1500 watt block heater an itty bitty pump running on a boiler isn't even noticeable. What is noticeable is a $28 a month nat gas bill instead of a $500 a month nat gas bill. The $28/month is my minimum I can pay with pipeline charge, maintenance  and all the other crap.
Ched Bull
  • OWF Model: mf 5000
« Reply #22 on: December 11, 2014, 11:00:38 AM »
All electric 1800 sq. foot home last November 380.00, this November 140.00  Yah Buddy this is freeking great! ;D
Stihl 261c, Home made 36 inch long 27 ton horazontal log splitter, John Deer 2520, 2004 Chevy Four Door Duramax 70,000 miles, Kirksville Mo.
aries9245
  • OWF Model: Cl6048
« Reply #23 on: December 24, 2014, 09:36:00 AM »
Man i couldn't be so lucky!   ???
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
treeeman00
  • OWF Model: MF5000E
« Reply #24 on: December 27, 2014, 12:57:55 AM »
I used to heat with all electric and my bill was usually $350-$380 a month.  Since I put my heatmaster in my bill is right around $100
Mike.Blount
« Reply #25 on: January 22, 2015, 10:13:45 AM »
I fired up my home made boiler in late November,  I live in Northern Indiana  It hasn't been as cold as last winter, but we did have a colder December it seems.  For my first bill there was a 1,900 drop in Kilowatt Hours.  I went from all electric baseboard heat,  to ducts, and a furnace and heat exchanger.  I didn't even hook gas to the furnace, I strictly use just the blower.   I'm anxious to see what its going to be for the January bill.
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #26 on: January 22, 2015, 11:54:15 AM »
. Was thinking and hoping that since the burner and fuel oil pump on the fuel oil boiler wouldn't be running the circulation pump and fan on the OWB would cancel eachother out,
The pump on the OWB is on continuously!
The fans come on when needed.
If your pumping water 24/7  your going to use more juice than when your oil/fuel pump comes on demand.
I guess?
kk
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
hrc200x
« Reply #27 on: January 22, 2015, 03:43:57 PM »
Yep, most of it is the pump, hooked it into a thing that tells you how much it would cost to run a month and it was about $12.50, so that plus the fan, and since the water is running cooler than it does with the fuel oil boiler (180 on fuel, 155-160 OWB after it transfers through the water to water exchanger) the zone pumps will need to run more often/longer than when fuel oil was used.
Pages: 1 [2]
