Author Topic: New boiler  (Read 5684 times)
Farmerfreddie
  • OWF Brand: None
  • OWF Model: None
New boiler
« on: December 04, 2014, 06:28:36 PM »
I'm looking into getting a portage and main out door wood boiler. Are there any dealers near Maryland that have the bl 34-44 in stock for purchase. I want to beat the EPA restriction on a gasser.
Re: New boiler
« Reply #1 on: December 05, 2014, 04:00:15 AM »
Call our office, they will let you know if there is a close dealer and if that dealer has any 34-44's left, we are behind in production, I think about 6 weeks, still and it's getting close to the deadline for non gassers, if you want one you had better act soon!
Farmerfreddie
  • OWF Brand: None
  • OWF Model: None
Re: New boiler
« Reply #2 on: December 05, 2014, 07:41:39 PM »
Thanks slim jim. I have to call and get some information. Hopefully something will be around in driving distance. I can't get even heat in my old farm house with my current wood stove and my oil burner is wore out and needs replaced. I wonder how far away from the outside wood furnace can you run the under ground pex pipe  and still heat the buildings you want to heat?
Re: New boiler
« Reply #3 on: December 06, 2014, 02:55:20 AM »
I have done 500 feet before with Logstor! is your farm house hot air or hot water heat, perhaps we can help with ideas?
Farmerfreddie
  • OWF Brand: None
  • OWF Model: None
Re: New boiler
« Reply #4 on: December 06, 2014, 04:57:29 PM »
It's hot water base board. The house is not insulated very well and I want to heat another smaller block farm house house. Wondering how much heat I can get out of the portage and main bl34-34? I might try to run a ceiling mount forced air in the dairy house also.
Farmerfreddie
  • OWF Brand: None
  • OWF Model: None
Re: New boiler
« Reply #5 on: December 06, 2014, 05:09:31 PM »
What is the best insulated pex line product and line size for heating? My neighbor is running a central boiler e classic and he has 1" pex. He said I might need 1 1/4" because of the size of my house.
Re: New boiler
« Reply #6 on: December 08, 2014, 03:23:20 AM »
Logstor, best construction in the industry, heaviest outer layer, one inch inside diameter pipe compred to .82 inch for other pipes, they are nominally sized, outside diameter
