Author Topic: Whats the best thermostat to get.  (Read 9260 times)
gandgracing
« on: October 26, 2010, 02:59:31 PM »
I'm still using the one that came with the stove and I would like to get one that has a range.  Say like 160-170.  Are they a pain to
install?  I have seen alot of different ones being used but I dont know what to get.  Dont think I want the strap on kind but the
submersible ones I think you have to make some kind of well????  I just dont know.......
BFB Builder
  • Where ever you go there you are.
Re: Whats the best thermostat to get.
« Reply #1 on: October 26, 2010, 03:48:26 PM »
I am using a simple Ranco temp controller with single no/nc contacts. It was easy to set up and fairly cheap I think $70.00 at a big industrial supply house. You can set a range up to 30 deg if recall correctly. I run my device at 180 with a 10 deg range so it opens my damper and starts my fan when water temp gets to 170. The well was about 35 bucks at the same supply house I am tighter than 2 coats of paint so I soldered a piece of 3/8 copper tubing to my incoming pipe and slid the probe in it then covered the whole thing with insulation worked nicely. Good luck.
« Last Edit: October 26, 2010, 10:09:25 PM by BFB Builder »
Owatonna  1700, Husky 575xp, 55 Rancher, Echo top handle, One big fat bastard homemade OWB
Russ Brumit
« Reply #2 on: October 31, 2010, 09:47:53 AM »
Heres one for under 50.00 . Ebay has them too.  search for  Ranco-ETC-111000
  http://www.pexsupply.com/Ranco-ETC-111000-Single-Stage-ETC-Temperature-Control-w-Sensor-120-240V-Input-11627000-p
Shaver  Series 290
443-907-7455
Russ Brumit
« Reply #3 on: October 31, 2010, 09:53:40 AM »
As for the well .  drill a hole about 14" back on the top of the furnace.  One guy just used a 12" piece of copper tube with a cap sodered on the end . At the top you can use a reducer or just flare the end so when you drop it in the hole the reducer will catch it.then drop in the probe from the ranco and put a little silicone around the hole to seal it up and your done.
Shaver  Series 290
443-907-7455
