Author Topic: Water Temperature?  (Read 9181 times)
intensedrive
Water Temperature?
« on: December 10, 2014, 01:03:55 AM »
I would like to set my water temperature to 185.  Seems in the program it won't let me go above 180.  Followed the instructions from the manual no luck.  Can anyone help
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Re: Water Temperature?
« Reply #1 on: December 10, 2014, 02:31:52 AM »
I would call Craig at Ridgewood.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Chas
« Reply #2 on: December 10, 2014, 05:56:07 AM »
The instruction manual is a bit confusing,  especially when trying to change the differential setting. I have mine set at 185 so I know it can be done.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
jamesbodeis
  • OWF Model: 7500
« Reply #3 on: December 10, 2014, 02:16:26 PM »
Yeah I've got mine at 195. Find the manual for the love aquastat that is on there. The instructions are still a bit confusing but it can be done.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
intensedrive
« Reply #4 on: December 11, 2014, 11:15:43 PM »
Curious to know why running the water so hot?
« Reply #5 on: December 12, 2014, 06:47:17 AM »
1: Hotter the water the less free oxygen that can be dissolved in it, less oxygen equals less corrosion
2: Hotter the water, the hotter the interior of the stove stays so less creosote and condensation so again less corrosion
automan77
« Reply #6 on: December 12, 2014, 07:11:08 AM »
Do you see a increase in your heat coming out of your vents in your house
Scott K
Stihl ms 311
Husky 455
jamesbodeis
  • OWF Model: 7500
« Reply #7 on: December 12, 2014, 09:29:02 AM »
I have 7 cast iron radiators on one loop. When the house calls for heat all 7 radiators get heated at the same time. I was seeing 30-40 degree temp drops at the stove. The stove was set to come on at 170 from the factory. That meant my water temps would get as low as 130-140 before they started to recover. Now my temps never drop below 165. My radiators do get hotter and heat the house faster. The whole system seems to operate better at the hotter temp.
Ridgewood 7500
Jonsered 2260
automan77
« Reply #8 on: December 12, 2014, 12:00:28 PM »
I'm gonna raise mine up to  190  tonight and see how that works out  .
Scott K
Stihl ms 311
Husky 455
