Author Topic: Large Water Volumes  (Read 9191 times)
fryedaddy
  • OWF Model: 750 Gallon
Large Water Volumes
« on: December 10, 2014, 07:39:19 AM »
Who has a stove with a large water volume?
How do you burn your fires?
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: Large Water Volumes
« Reply #1 on: December 10, 2014, 05:07:21 PM »
What do you consider a large water volume?
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
sizmo
  • OWF Brand: Acme
  • OWF Model: 340
« Reply #2 on: December 10, 2014, 05:10:36 PM »
My furnace holds 340 gallons of water which is a large water volume.
I have mine set to about 170*
Load it about twice per day.
Hope that helps.
Sluggo
  • OWF Brand: Heatmaster SS
  • OWF Model: 20,000e
« Reply #3 on: December 10, 2014, 05:28:39 PM »
Mine holds 555 gallons.  Load twice a day.  My old stove held 265 gallons.  I thought the extra water capacity would reduce wood consumption but I don't believe it has.
Stihl 441
Stihl 660
Stihl 029 Farm Boss
Bobcat T190
Grapple
Farmi 501 Winch
« Reply #4 on: December 10, 2014, 10:58:44 PM »
My homemade holds roughly 275, if in the frenzy of harvest I forget to load it at night, and as long as it's not too cold out the house is still warm in the morning.
Working on getting my waste oil boiler hooked to the wood boiler. Waste oil boiler holds 425-450ish, I figure unless its utterly stupid cold out with almost 700 gallons of hot water I should be good for a forgetful night once in awhile.
fryedaddy
« Reply #5 on: December 11, 2014, 06:58:48 AM »
 I was thinking of 500 plus gallons.
I don't believe it conserves any energy I was just wondering how you burned, like a smaller stove with the fire cycling on and off or batch burn.
I batch burn with mine, it holds 650ish gallons and I'll burn the fire full out till it gets up to 180 then use that heat. It normally last 12hrs or so so I burn twice a day.
I do live in a milder climate (N.C.) than most on here so a large volume of water may not be as efficient in the north.
How is everyone else burning with storage?
Hammersquash
  • OWF Brand: Empyre
  • OWF Model: 200 ProHS
« Reply #6 on: December 12, 2014, 04:44:22 PM »
  My Empyre 200 holds 75 gallons.... Not very much in comparison.
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
2012 F250 King Ranch 6.7 TD
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
« Reply #7 on: December 13, 2014, 11:27:03 AM »
Here is a quickie calculator to figure out what water storage may do for you!
http://www.hearth.com/econtent/index.php/articles/using_storage_tanks_with_biomass
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #8 on: December 13, 2014, 06:03:55 PM »
i batch burn with mine also.the whole system is about 500 gallons.load it about twice a day also.
the only thing is my firebox is small so it seems to work better when i batch burn with mine.
and hardly ever any smoke except for ten minutes at the beginning.
austin qc
bluegrass rules
proud appalachian
