Author Topic: Btus  (Read 7518 times)
coolidge
Btus
« on: December 14, 2014, 12:41:50 PM »
Is there a way to figure how many btus your furnace is actually producing?
Western Maine
artbaldoni
  • OWF Brand: Nature's Comfort
Re: Btus
« Reply #1 on: December 14, 2014, 02:38:20 PM »
A Btu is what is required to raise one pound of water 1°. I guess if you know how much water you have and have a way to track temp rise over a period of time you can figure Btus per hour. I think... :o
Nature's Comfort  NCB-175
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
Bobcat 7753 w/EEL Tracks
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: Btus
« Reply #2 on: December 15, 2014, 05:41:00 PM »
A lot of variables there. Wood type , moisture  content, water volume and fire box size to name a few.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
cando attitude
  • OWF Model: BL 28-40
Re: Btus
« Reply #3 on: December 15, 2014, 08:23:14 PM »
Assuming that you're talking about your furnace opposed to your boiler, there's two things you need to know to determine the btu rating:  temperature change (delta t) and flow rate of air (cfm).  By looking at the specific heat capacity of air at these two temperatures and knowing the delta t, you can calculate the btu output.
Cando
Echo CS 400
Jonsered 2255
Case 35B
Dirty hands splitter
2013 3500 Duramax
free heat
  • OWF Brand: ridgewood
  • OWF Model: 6000
Re: Btus
« Reply #4 on: December 15, 2014, 11:59:31 PM »
 :post:
Ridgewood 6000
Stihl 039, 290
Fiskars x27
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: Btus
« Reply #5 on: December 16, 2014, 12:13:26 PM »
In a roundabout way, you could figure the btu's used by your house, domestic water, and heat loss on your line, thus coming up with the total.
jreimer
  • OWF Model: Optimizer 250
Re: Btus
« Reply #6 on: December 17, 2014, 09:38:49 AM »
The easiest way that I have measured the output of my furnace is by timing how long it took to raise the water temperature a set amount, (say from 140 to 180) leaving a circulator running to ensure all the water in the furnace gets heated equally.  Do not put a heat load on your stove while doing this.
Knowing the volume of water in your stove lets you easily calculate the btu output.  I have calculated this value in multiple ways such as mass of wood burned, efficiency rating of the stove etc. and the numbers all seem to match each other fairly closely so I am confident in my results.
Shindaiwa 488
GMC Duramax 2500HD
Homemade splitter
Kubota B7500 w/loader
An understanding wife
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Btus
« Reply #7 on: December 17, 2014, 11:51:03 AM »
Easiest and most accurate way would be a heat loss calculation on the buildings ur heating. You would adjust the temps in the calculator for indoor and outdoor temps over the time period your testing. Close monitoring of these temps will give you a number with the lowest error rate.
HLC programs have built in fudge factors, how much depends on which one you use. I recommend using John Siegenthalers , as they are very accurate. But not necessary to spend.  Using other math / wood & water/ time etc, formulas just have more likely for higher error. Good luck
Michigan Thumber
