Author Topic: High Limit Temp and differential Changes?????  (Read 13429 times)
tinfoilhat2020
  • OWF Brand: POS
« on: December 15, 2014, 03:55:14 AM »
Question for the forum:
Who here has raised their high limit? I currently have mine set at at L:165-H:175. I have notices that the natural draft system takes way longer to recover and my water temp will get down to 150 before beginning to make a climb. What temps are others running out there??? im curious to know??? Im  running baseboard water heaters in my 1500 sqft home.
Also, is it normal to here the water boiling inside the stove??? I have never had a boil over and my temp never goes above 175, but it is loud standing next the boiler before it reaches its high limit. Just wanted to know if anyone else has experienced this.
Thanks,
Dylan
Chas
Re: High Limit Temp and differential Changes?????
« Reply #1 on: December 15, 2014, 05:56:59 AM »
I have mine currently set at 185 high and 173 low. I will raise the low setting when it gets colder just to experiment with it a little more this year. I can hear the water boiling in mine too. Mine will occasioanlly overshoot alittle but never over 187.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
jamesbodeis
  • OWF Model: 7500
« Reply #2 on: December 15, 2014, 06:11:38 AM »
195 high, 190 low.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #3 on: December 15, 2014, 07:18:31 AM »
Changed mine to high 185 and low 180 yesterday.   See how that works  out  when it gets colder
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
tinfoilhat2020
  • OWF Brand: POS
« Reply #4 on: December 15, 2014, 10:24:45 AM »
thanks for the input! i think i need to raise my high limit it looks like!
fsuftball
« Reply #5 on: December 15, 2014, 01:51:53 PM »
180/170 here works fine for me.
Burning all seasoned ash split.
Got down to 150 with poplar but still blew out warm heat.
automan77
« Reply #6 on: December 15, 2014, 03:41:15 PM »
Just changed mine to 185 - 175.
Scott K
Stihl ms 311
Husky 455
Vincent Paul
  • OWF Model: 7500
« Reply #7 on: December 16, 2014, 05:43:15 AM »
Just started ours up on Friday and it is set at 180/170.  It's been warm here in southern Indiana so I assume I may have to move the temps.  I am currently running our Honeywell pump on low, should I assume when it gets colder I'll need to move it to medium or high?          vpm
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
automan77
« Reply #8 on: December 16, 2014, 08:20:09 AM »
I leave my bell & Gosset on medium  all the time.. Might bump it up to see if it makes a difference one day.
« Last Edit: December 16, 2014, 11:42:32 AM by automan77 »
Scott K
Stihl ms 311
Husky 455
tinfoilhat2020
  • OWF Brand: POS
« Reply #9 on: December 16, 2014, 10:09:08 AM »
thanks for the input everyone. I changed my settings to 180-175 and it seems to be working a bit better. now it only dips to around 167 at the lowest and there is less creosote built up
Uponthehill
  • OWF Model: 250 & 461 Stihl
« Reply #10 on: December 16, 2014, 08:15:34 PM »
Mine set @ 190 +/- 8 degree.  May creep to 193, but no issues so far.  Hotter fire = less creosote.  Stay warm....
fsuftball
« Reply #11 on: December 19, 2014, 09:39:14 AM »
mine was 128 this morning.. didnt put enough wood in it it was all gone.
threw some ash in there with some small rounds of maple.
180 in 1 hour.
26 degrees when i got up this morning..
so people that went from 180 to 190, burning more wood? what are the results automan
jamesbodeis
  • OWF Model: 7500
« Reply #12 on: December 19, 2014, 02:08:18 PM »
I guess I dont know. I dont find myself putting anymore in. It doesnt seem to run any more than it did but when it does it doesn't run as long.
Ridgewood 7500
Jonsered 2260
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #13 on: December 30, 2014, 07:14:34 AM »
Does anyone have a link to the controller manual? The Ridgewood stove manual does not go into great detail on settings.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
jamesbodeis
  • OWF Model: 7500
Ridgewood 7500
Jonsered 2260
