Author Topic: BUILDING MY OWN OWB...NEED TIPS!!!  (Read 9079 times)
tinfoilhat2020
  • OWF Brand: POS
« on: December 16, 2014, 10:06:51 AM »
hello everyone,
I have a 500 gallon  oil tank (1/4 thick) and a 500 Gallon Propane tank (3/8 thick). The Diameter of the oil tank is much larger than that of the propane tank. The oil tank is shorter, propane tank is narrower and longer. Oil tank will serve as my water jacket and propane tank as my firebox. I have everything i need as far as design but i have one simple thing im unsure of:
HOW WOULD YOU MOUNT THE FIREBOX INSIDE OF THE WATER JACKET??? they are both cylinders.
thanks...any pics or input would be great!!!!!!
Re: BUILDING MY OWN OWB...NEED TIPS!!!
« Reply #1 on: December 16, 2014, 12:11:08 PM »
I HAVE NEVER BUILT MY OWN BOILER.  Ok that is out of the way
Thoughts:
Water circulation is important, and lack of circulation causes hot spots and ISSUES
No one ever complained about too many ports on a boiler (as long as you are a good welder, or know one...)
I would think you want the firebox to be shifted towards the bottom, of the water jacket, as hot water rises and hottest part of fireboxes are generally the TOP!
**Don't skimp of insulation, ANY heat that is released could have gone into your sturcture and thus you need more WOOD to keep house warm.
...other smarter people will add more!?  I HOPE
Also remember we like  :photo: of progress and successes
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
fryedaddy
  • OWF Model: 750 Gallon
« Reply #3 on: December 16, 2014, 03:11:54 PM »
The only thought I can add would be to make sure the flue goes through the rear of the unit so rain
can't go directly into the firebox!!
Jd79
« Reply #4 on: December 16, 2014, 03:46:30 PM »
Here's a link to the one I built this year. I will try to update with final pictures soon:
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=4634.0
« Last Edit: December 16, 2014, 03:48:35 PM by Jd79 »
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #5 on: December 16, 2014, 05:52:37 PM »
Good luck.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
tinfoilhat2020
  • OWF Brand: POS
« Reply #6 on: December 17, 2014, 05:54:14 AM »
thanks everyone.
I have the tanks available for it is going to make for a fun project for my buddy and I. I already have a great OWB in place, so i wont have to rush anything. Just looking for good deisng ideas/tips. I am going to keep it as simple as possbile.
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
« Reply #7 on: December 17, 2014, 08:54:34 PM »
thanks everyone.
Ayuh,....    Mine is a big propane tank, inside a bigger water softener tank,.....
I tacked 4 pieces of 1" rebar in the bigger tank, so's the big tank sits on 'em, 'n has an inch of space all 'round the bottom, growin' larger to the top,...
The return water ports are slightly forward of center, near center side to side, the hot water out ports are at the top aft corner, 'bout center,,...
It holds 'bout 110 gallons of water total,...
« Reply #8 on: December 19, 2014, 07:11:26 AM »
With very little "thought" required, it would be rather simple to design a firebox shape that can utilize convection currents inside the water jacket to encourage agitation of the water and suspension of any solids in the water for filtration during water circulation.
« Reply #9 on: December 19, 2014, 07:22:52 AM »
I think what Mr Snood meant was with two round tanks it's pretty hard to screw the pooch.
