Author Topic: Damper Fan  (Read 9095 times)
BenGrove
  • OWF Model: MF3000
Damper Fan
« on: December 16, 2014, 08:38:55 PM »
Hey friends,
My temp was having trouble getting passed 140 this morning despite a good fire going in the firebox.  I noticed my fan was louder than normal as it was on trying to kick up the heat. Is there a way to clean the fan or inside the blower? I'm wondering if that's the problem. I took out the whole pan to clean out extra ash down there, but it's still louder than normal. Thanks for words of wisdom!
Oh I have the heatmaster MF3000
DaveWertz
  • OWF Model: H4
Re: Damper Fan
« Reply #1 on: December 16, 2014, 09:31:39 PM »
Do you ever oil it? Depending on which fan you have there should be ports so you can oil them. When they start to make noise is when there on there way out. Found that out first hand last winter and was stuck without one for a few days. Do yourself a favor and order one asap and keep it on hand as a backup!
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Damper Fan
« Reply #2 on: December 16, 2014, 10:18:06 PM »
Do those fans have a damper that might be stuck closed not allowing the air to pass through? If they do and its not opening that would cause the fan to sound different and not allow your fire to burn like it should.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: Damper Fan
« Reply #3 on: December 16, 2014, 10:19:10 PM »
They act like that when they need oil.
BenGrove
  • OWF Model: MF3000
Re: Damper Fan
« Reply #4 on: December 17, 2014, 09:25:34 AM »
If someone owns a heatmaster, can you tell me what oil and how much and how to do this? Thank you!
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Damper Fan
« Reply #5 on: December 17, 2014, 11:00:08 AM »
I've been told our fans don't need oiled.  If you are under a year, contact your dealer and see if you can get a new fan.  I think the fan is warrantied for 1 year.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
userdk
  • OWF Model: G 400
Re: Damper Fan
« Reply #6 on: December 17, 2014, 03:50:12 PM »
WD 40 works. I think the sealed bearings are a thing of the last few years. If it's a little older there should be a little oil hole somewhere.
DaveWertz
  • OWF Model: H4
Re: Damper Fan
« Reply #7 on: December 17, 2014, 06:38:05 PM »
3 in 1 oil.
Stihl Farmboss 290
Jwood
Re: Damper Fan
« Reply #8 on: December 17, 2014, 09:36:50 PM »
Did you figure it out?
Stihl MS 270c
Stihl MS 461
BenGrove
  • OWF Model: MF3000
Re: Damper Fan
« Reply #9 on: December 18, 2014, 10:09:47 AM »
Nope, called my dealer, he said he's never heard of needing to put oil but he said can't hurt it.  Haven't had a chance to see if it works
