Author Topic: Huskee 35 ton engine  (Read 11189 times)
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« on: December 22, 2014, 06:42:27 AM »
I'm looking to replace the hard starting, recoil eating 12hp B&S on my 12 yr old Huskee/Speedco/TSC 35 ton splitter. I know there is a "cold/hard start bulletin" on the engine but figured after parts and labor It would be just as cost effective to replace the entire thing. Any suggestions?
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
stewie3500
  • OWF Model: C375
Re: Huskee 35 ton engine
« Reply #1 on: December 22, 2014, 07:00:42 AM »
Roscoe,
There are many opinions on this one.. I will offer mine. As a small engine mechanic for 10 yrs by trade and part time for 7, the Honda GX series is hard to beat. The 390 would be the closest replacement.
Ram 4500 C&C
Load Trail 14k dump trailer
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
« Reply #2 on: December 22, 2014, 07:51:49 AM »
Seems like they have two series of those Honda engines though, the one on my power washer you need to keep it somewhere warm or you'll pull your arm right out of the socket on colder days (below 50) while the one on our seed tender starts the first pull every time.
« Reply #3 on: December 22, 2014, 07:59:25 AM »
I know that some will disagree with me here but it is worth looking at the honda clone engines from harbor frieght. Just make sure you open the box before you leave the store to make sure everything is in order.
stewie3500
  • OWF Model: C375
« Reply #4 on: December 22, 2014, 08:30:01 AM »
Mlappin,
You are correct. I would lay money down that the hard starting honda is a GC series. Honda created an affordable engine several years ago to compete with the " knock off"  market. These are easily identified by their plastic recoil housing and fuel tank. The reliable model you speak of is a "Gx" series. Hugh differences from ball bearing supported crankshaft to plastic camshafts.
Ram 4500 C&C
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
« Reply #5 on: December 22, 2014, 11:11:56 AM »
You're correct stewie, the seed tender uses a GX and the power washer is a GC, went and looked this AM to confirm. Starters for the GX are stupid expensive I've found, it starts so well I haven't even bothered changing the starter.
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
« Reply #6 on: December 22, 2014, 01:07:03 PM »
So the GX is the one to get?
Right now my B&S is a vertical shaft. I'm no mechanic and I'm wondering how difficult it would be to swap vertical for horizontal?
Also, is there anyone on here that deals in these type engines.....would like to support sponsors/members??? If not, who is a good dealer?
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
JTS717
  • OWF Model: Optimizer 250
  • East-Central Wisconsin
« Reply #7 on: December 22, 2014, 01:27:06 PM »
Is the engine direct coupled to the hydraulic pump or is there a chain or belt that run the pump?  If the pump can handle the same RPM as the pump and is direct coupled then switching from vertical to horizontal should be easy as long as you have the space and enough hose length.  Where are you located?
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
« Reply #8 on: December 22, 2014, 07:09:12 PM »
JTS717
Thinking its direct coupled...I'll have to check. I'm in southeasten Michigan
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
aries9245
  • OWF Model: Cl6048
« Reply #9 on: December 27, 2014, 05:58:15 AM »
I have a knock off Honda 17hp electric start on my homemade splitter it's going on 5 yrs spots about 20 cords a yr starts right up every time it's called Duromax. I've been looking can't find them as before but there still around $285.00 from ebay shipped
Found a whole bunch do a search they all come..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
aries9245
  • OWF Model: Cl6048
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
