Author Topic: Water Level  (Read 9334 times)
Vincent Paul
  • OWF Model: 7500
Water Level
« on: December 22, 2014, 02:46:56 PM »
I've noticed on my Ridgewood 7500 that the site glass showing water level is around 3/4's full (the site glass is 3/4's full )  Is this normal for all of their stoves?  When we made the initial fill of the stove 2 weeks ago, it, it peed out of the top of the site glass until we are at the level we are at now.  Just curious.  So far, love the heat and the awesomeness of the stove.  Wishing all of you a warm and very Blessed Christmas..............Vincent Paul Meyers
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
Chas
Re: Water Level
« Reply #1 on: December 22, 2014, 03:41:40 PM »
Mine also sits at 3/4 full in the sight glass. I think thats normal for a Ridgewood. If you watch the level, it changes slightly depending on the temperature of the water. If it were to get hot enough, you might see it pee out of the sight glass some more. Merry Christmas!
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
free heat
  • OWF Brand: ridgewood
Re: Water Level
« Reply #2 on: December 22, 2014, 05:50:16 PM »
Chas is exactly right, I do know tap water to 180 degree water will expand up to 4% in 200 gallons that would be 8 gallons. So that's why you see the sight glass vary in levels depending on the temp of the water. Try to keep it around 3/4 full on the glass at it's coldest setting when the trap door opens.
Ridgewood 6000
Stihl 039, 290
Fiskars x27
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
Re: Water Level
« Reply #3 on: December 22, 2014, 07:17:39 PM »
X2
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
automan77
  • Just say no to propane
Re: Water Level
« Reply #4 on: December 23, 2014, 02:17:00 AM »
My water level is about  3/4 on the glass.  I added a half quart of treatment the other day and it pissed out a little bit.  It's full
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Vincent Paul
  • OWF Model: 7500
Re: Water Level
« Reply #5 on: December 23, 2014, 04:42:21 AM »
Thanks guys, I knew I could rely on the Ridgewood owners to help.  54 degrees here today - 28 on Christmas.  As always, thanks for taking your time to help out..........vpm
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
intensedrive
Re: Water Level
« Reply #6 on: December 25, 2014, 10:21:13 PM »
Mine sits a little above half most of the time.  Its about half now.  I will go out soon and pour a milk jug or two of water in the vent tube.
Chicken farmer
  • OWF Model: 2000
Re: Water Level
« Reply #7 on: December 28, 2014, 07:18:28 AM »
When I filled mine, I ran it over out of the vent tube. I drained some out until it showed about 3/4 on the sight glass. As the stove was coming up to temp, it continued to vent out of the sight glass weep hole. Now it sits at about 3/4 all the time running at 180 degrees.
Midwestern Ohio
