Author Topic: Rancher 365  (Read 14487 times)
George Scofield
  • OWF Model: CL 6048
  • America!!!
Rancher 365
« on: December 26, 2014, 06:41:13 PM »
I'm torn between a rancher 365 from earth and a used cb6048. Just wondering if any of u guys have anything at all to say about either one. Thanks for any help
Stihl 056 av magnum II
Husky 25 ton splitter
2012 ram 1500
scarface77
  • OWF Brand: earth outdoor wood furnace
  • OWF Model: mountain man 500
Re: Rancher 365
« Reply #1 on: December 26, 2014, 08:48:39 PM »
I have the mt. man 500 and love it, it definitely does the job!!! Just don't go cheap on the underground pex like I did because I had to replace it and it was costly. I installed LOGSTOR as my replacement and WOW what a difference!!! This is a great site for info and to learn from.
Earth Outdoor Wood Furnace Mountain Man 500
Huskee 35 ton log splitter
Stihl ms 290 chainsaw
George Scofield
  • America!!!
Re: Rancher 365
« Reply #2 on: December 27, 2014, 07:30:34 AM »
Thanks for the input my friend. I'll be in here for good.
2012 ram 1500
Farmer85
  • OWF Brand: Earth
  • OWF Model: Rancher 365
Re: Rancher 365
« Reply #3 on: December 30, 2014, 08:51:18 PM »
I have a rancher 365. I like it just fine. Does exactly what I want. There's a few things I would change if I could but overall I love it. I bought a used hardy before this and won't be doing that again. Also ditto on good underground. I got the stuff from dealer 3 wrap and it is leaking ground water in pipe. I will have to redo. 1400 at my expense. Ouch
If your wondering what I would change
Water overflow in front left side of mine, so I learned to fill with wood then top off water otherwise it can belch hot water on your arm. Also sometimes I wonder if I should of got a ash pan. Argue all you want but it is nicer to clean. In hindsight I chose the 365 for the bigger door which I love. Also the light isn't very good on front. I gave up and put one on my shed facing the owb and wood pile. Works better anyway. None of these are Much to complain about and I would buy another if I had to.
Sullivan Mo
Earth rancher 365
Stihl ms250,ms260pro,ms290,ms034,ms460
Skidsplitter,gas powered splitter and shiny mall
Re: Rancher 365
« Reply #4 on: December 30, 2014, 09:18:19 PM »
Ditto on the underground line, bought a 250' roll of Logstor earlier in the year and haven't regretted it, well other than the size of the check, but I got over that once it was installed and had water in it.
