Author Topic: Time to upgrade?  (Read 11775 times)
Log hog
Time to upgrade?
« on: December 28, 2014, 09:06:25 AM »
New member here. Been heating with wood for 20 years. Outdoor boiler for 5 years. I'm sure this has been discussed on here but didn't seem to find what I was looking for in search. So thank you in advance for putting up with me.
I heat a 2800 sq foot home, basement, and hot water. I have forced air in house, some baseboards in the basement, a garage style modine heater in part of the basement and a plate exchanger on the h2o. I have a classic 5036 that keeps up but I would like to add a 30x40 shop and garage and hot tub in the future.  Been thinking about going to a cl6048. Thinking I would be able to get longer burn times, use crappier wood ie poplar, cedar, pine later in the season than I currently do.  I switch to good hardwood when the temps get down to 20 at night now.  Part of the thought process comes with the fact that the classics will be discontinued in spring.
Help me pick apart and analyze this decision. Thanks
Bobcat S650 with root grapple
New. Holland tractors
Stihl 029&250
Husky 570
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
Re: Time to upgrade?
« Reply #1 on: December 28, 2014, 09:53:24 AM »
If you're gonna do it, NOW is the time. You won't have that option in a couple months. I replaced my 6 year old 6048 because I wouldn't have the option much longer. Especially if youre adding more ft2.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
aries9245
  • OWF Model: Cl6048
« Reply #2 on: December 28, 2014, 11:06:31 AM »
I'm heating 4200 sq ft high ceilings on an open hill constant wind winter months  installed 6048 fees weeks ago and I am averaging 14-16 hr burns time I'm not loading all the way either below half 24-30" pieces long I'm sure it will change when temps drop but I'll just put alittle extra.. I luv it
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
fireboss
« Reply #3 on: December 28, 2014, 01:04:22 PM »
I burn pine all year long with no problem  the 6048 is the way to go  its the same thing as the 5036 so you won't have to learn a new stove !
Log hog
« Reply #4 on: December 31, 2014, 02:11:23 AM »
Well I pulled the trigger on a new 6048. Can't wait. What do you guys think a 5 year old 5036 is worth? New one is $6500 plus tax. It's in fine shape, little rust below the door, little soot above it.
Stihl 029&250
Husky 570
aries9245
  • OWF Model: Cl6048
« Reply #5 on: December 31, 2014, 08:15:06 AM »
I'd say about 3grand..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Big Wood
« Reply #6 on: December 31, 2014, 05:21:43 PM »
Take a look at the Portage and Main outdoor wood furnace BL 3444 had good results from customers
fireboss
« Reply #7 on: December 31, 2014, 06:16:08 PM »
Iam sure you will be happy!
aries9245
  • OWF Model: Cl6048
« Reply #8 on: January 02, 2015, 07:07:06 AM »
Nice good choice!  :thumbup:
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Log hog
« Reply #9 on: January 02, 2015, 10:24:55 AM »
Big wood. You have a central boiler but sell portage and main???? Please explain
Stihl 029&250
Husky 570
Big Wood
« Reply #10 on: January 02, 2015, 04:57:32 PM »
I buy and sell and repair used outside wood boilers for the past 8 years as with anything new technology move things in a new direction there stoves in my opinion is one of a good design i run a CB because it is what I could afford at the time it was used i like to help people get on wood keep your money local
Log hog
« Reply #11 on: January 02, 2015, 06:55:35 PM »
Makes sense. Thanks for the explanation.  I looked at the portage and main. My big thing about the gasification units is the need to have well seasoned wood.  Extra splitting to get it to dry and being a year ahead is not in the cards for me. I burn a lot of junk wood and a fair amount of large chunks of semi wet.  I try to eliminate as much handling as possible. Hope I am making the right decision?????
Stihl 029&250
Husky 570
Big Wood
« Reply #12 on: January 02, 2015, 08:09:40 PM »
Look at the BL 3444 shaker great model its all about putting the energy in the water and a lot lower stack temperature then a CB 6048 plus the boiler is made to be taken apart if needed just a thought
Log hog
« Reply #13 on: January 16, 2015, 07:06:53 PM »
 Got home at 3 this afternoon with the brand new 6048 :thumbup: the water temp in the 5036 was down to 130.  Shoveled it out unhooked it and got the new beast up and running. Fire started in the 6048 by 6 and it's up to 120 now and rising. The thing is Giant compared to the old one. I think I will fill it up tonight and maybe again in February. Took forever to fill with water.
Stihl 029&250
Husky 570
« Reply #14 on: January 17, 2015, 03:23:07 AM »
Log hog - Fill us in on your first night with the CB6048 when you have a chance.  Cold here in New England (NH); few degrees below zero with a stiff north wind.  Brrrrrr.....  Roger
